i seriously hope no idiots turn up to this event....
the next one i think we should make an SAU only cruise... wether or not it will be an official cruise or not will depend on when we get the club up and running.
id say we can organise another non-affiliated SAU forum guys cruise tho
  • Replies 299
Originally posted by lowlux
IM UP FOR IT!!!!!!!!! but inark u said no idiots can come,that means i cant come :D
but ill be good but ill just behave myself thats if all goes well and i get my car running alright
there are exceptions :(
Originally posted by RPMZ
Hope you guys don't mind an old 240z coming.............:P
if its ur 240z then i'll be damn happy so i can take some nice pics of it for me to drool over :P
wow what an great response
ermmm i hope it doesnt turn our too huge to handle..
about arthurseat being closed of??? :eek:
i hope not!!!
just pleaseeeeeeeee becareful on those twisties guy
if u feel unsafe at anytime try pulling over and let the cars pass infront of u and try stick to the back
last thing we need is any unfortunate accidents
Originally posted by inark
dont be a wuss!! all the more reason to come :P
So where u going instead?
well my bday is the 9th of jan, one of my mates is the 6th, and my other mate is the 11th... so its going to be a pretty crazy weekend.. I dont think I will be getting anywhere near the drivers seat of a car :P
Guest INASNT
i hope not!!!
All the roads to Arthurs Seat are currently closed! It might be still closed by Friday!
Guest INASNT
we havent printed out the maps as yet..
we gonna discuss it tonight and make an alternative route incase the roads are still closed
so not to worry!!
denham will u be in attendance?
Not 100% sure now as my car is going in to ICE on friday to get the cooler done
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
