  • Replies 299
I've spoken to Gerald and he reckons that one way or the other, you'll be in a shape to cruise :P
We're gonna have to kick you out at some point though coz we wanna cruise in my car and try it through the twisties :P
Originally posted by INASNT
Hes making the piping for me 2!
And as all mechanics do they wont just be working on 1 job
Guest INASNT
Originally posted by Leewah
I've spoken to Gerald and he reckons that one way or the other, you'll be in a shape to cruise :D
good to hear. now give me a discount 2!!:P
DO u have the piping at the shop already?
If u talk to gerald again can ya ask him to make sure its 2.5 inch piping!
According to Gerald, the piping will be 2.5" but it has to be fabricated. Apparently the HKS piping would suit your needs but that's up to you.
He also said that coz you have a SAFC installed, it probably wouldn't be the best idea fitting it all and going for a cruise as the AFC needs to be tuned again considering the new levels of air going into the system.
I think the best course of action is to fit the IC but not plumb it up until next week when we can get you on a dyno to tune the AFC.
If you have any questions, give Gerald a call on his mobile which is 0414 359 888.
Guest INASNT
fark that i want it all installed as i came back to work today and am 2 busy to take the car in twice!!! Also i can get the s-afc retuned on sat at race hopefully!
Sorry dude, this has now gone over my head. You'll have to call and speak to Gerald about this one.
I don't do the work, I'm just the messenger...
Guest INASNT
no prob i will talk to him!
I am more conserned about getting it all installed and running properly rather than going on a cruise!!:P
ICE is pretty busy this week, I won't be able to get my front caster rod bushes done until next Monday... :(
My corner handling is a bit crook now, you reckon it's pretty safe to go on a cruise, what are the twisties like?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
