  • Replies 299
Hi Greg,
How did you feel when HICAS screwed up? Is it kind of getting that wobbly feeling in the rear end when cornering?
I felt that too, not sure if that's also my rear suspension bushes due for replacement, or hope not, touch wood, not the HICAS please..
Rianto
Originally posted by SS8_Gohan
sorry for putting this in here, but i couldn't pm u inark. i'll need that lift buddy. thanks!! :(
no worries...
try pming me again with ur address so i can pick u up.
hey rianto,
that is exactly how it feels -- very unstable at the rear when cornering. it wants to oversteer at the slightest excuse. eg i go over a bump - the rear kicks out. drive over a bit of gravel on the road - rear kicks out. i'd hate to see it in the wet.
i am just assuming its the hicas because i did the diagnostic and 3 errors came up, but it could quite possibly be the bushes because they are getting pretty old...i hadn't thought of them actually. i might take it to ICE or somewhere and get them to have a look at it.
Greg
Originally posted by rs73
Hi Greg,
Rianto
guys, im just writing out the route for the night and we have a couple of problems that i wanted to discuss
first off: when we say "albert park pits" were refering to Aughtie Drive on the pit straight yes?
ok, other stuff is
this is showing hints of being a big turn out cos there are several clubs that are coming, and because iv mapped out a route with with some tight twisties streets and high speed sweaping turns im affraid it may be a problem with anything more than 20 cars
suggestions people:
1. stuff it, lets take the route thats mapped
2. keep it sedate, hwys and main roads
If this is gonna be a big turnout, will the Albert Park pits hold us all? It's not exactly the World's largest car park....
Also, I think that we keep the route that you've mapped out but make sure to make it clear to everyone that noone is responsible for the actions of others and in no way does SAU condone reckless driving, speeding, etc. All risks are at the owner/driver's responsibility.
Make sure that it is clear that this is not a race and people are advised to drive within their own limits.
Just my 2c worth.
ok, other stuff is
suggestions people:
actually, i was going to suggest we meet up at the carpark further down the road where RedHeads use to be...
Melway Ref 2KE6, its a pretty big carpark, should be enough
ill keep the route, ill make the suggestion that its not a race but theres always going to be a hand full of tossers
also, authers seat carpark isnt that big either and i doubt it can hold anymore than 20cars up there
ill work something out though
looking fwd to fri night...guess it shouldnt be hard to find , considering there will be quite a few imports in the one spot !!!
i will be departing the cruise at frankston area, not a fan of the twisties, in my car at night with a heap of others just at this stage of my skyline driving experience yet hehe
see you guys there...look for me to be at the back of da pack all the time hehe
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
