  • Replies 299
Originally posted by ice180
so we can capture all ambs sexy moves?
hahaha
nooooooooooooooo!!!
keep the cameras away from me unless u want my knee lodged into ur manhood!
hahaha
i will be too busy running round trying to keep things in line!!
heheh yesh lil me .. ooohh supawomann!!! :run:
and keepin the heros from pulling ful shik shkids at the meet point re
there are gonna be too many nice cars there for some silly bois to ruin it for everyone and have the cops show up and have a field day
so if u guys see anyone on the verge of attempting anything heroic please stop them asap!
:D
ambz are you getting aggressive... coz apparently horny chicks get aggressive...
Anyways, I'll bring my camera, along with 128mb of storage and 2 battery packs heheh... and tomorrow morning I'm gonna try out my Scratch X stuff ;) n polish mah beyatch up. The guys from J-Spec should be coming too including a nasty 300zx TT.
Dunno if I'll make it in time tho, I finish work at 8 :D
woooahhhhhhhhhhhhhh
morningggg guysssssssss!!!!!!
gonna be a nice dayy fingers crossed for a nice night aswell!!!
ooooohhhh me and whistla checked out the the cruise route last night
mapped it all out
with some nice stops along the way!
ooohhhhh its gonna be goooddddd
heeheh god damn twistiesss oohh gotta love emm
just hope everyone drives to their own limits
if u dont knwo these roads i suggest u stick to the back and take it easy
no need to rush
so yeah alll is goooodddddddddddddd
skyline33 whistla will be emailing me the map so send me ur email and ill send u a copy
should be an interesting night
dont forget ur cameras!!! oohh a flash will be handy aswell !!
yeee see you all there id most likely be in a black supra or whistlas burgandy 33 or and white 33 gtr so say hello i dont bite (no smart ass comments please)
hope to see u all there!!!!
brendan..
:shake: :shake: :shake:
hihihi just kiddin hun
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
