  • Replies 299
skyline33
i didnt realise ur cruise was for next week
cause i was gonna have that big jap cars cruise start of feb..
next friday few us us were gonna take the route to try it out with few cars..
i got my mate organising the arthur seat route..
so im thinking.. how bout we put em together.. instead of just lines only how bout we merge my mates with the rest of the people attending this cruise..
that would make an added..
3 s15's
s14
soarer
r33 gtr
r32 gtr
veilside silvia
r34 gtt
3 supras
gto
r33 gtst
fto
gtir
wrx sti x 2
and few others??
anyways just a thought...
Originally posted by MZNISMO
skyline33
3 s15's
s14
soarer
r33 gtr
r32 gtr
veilside silvia
r34 gtt
3 supras
gto
r33 gtst
fto
gtir
wrx sti x 2
and few others??
thats fine with me, the more cars the better i think. so do you want them to come on the 10th with us??
yep im thinking might aswell just combine them both together
cause wed be taking the same route anyways
want me to advertise in on the unnoficial section in mccr for jap cars only for a bigger turnout?
up to u...
just gimme the details..
and might be easier if we pushed back the meeting time to bout 9pm depart at 9:30???
ill get the map to u asap
u got a email addy?
Originally posted by skyline33
Update: The meet will take place at 9:00pm in front of the albert park pits and we depart 9:30.
MZNISMO: check your PM
might wanna update it in the original post if u havent already
just saw this thread but I am pretty keen to come along...voted as a maybe...route sounds good but me thinks more advertising [mccr etc] the more likely for cops to show up :confused:
Not that it will affect my car but the Elwood carpark has a few speed humps...just letting ppl know that may have low-rides.
cops can come for a cruise! thats all good :)
not like we're going on this cruise to cause trouble anyway (i would like to think the guys on here are a lot more responsible than the MCCR dikheads!!!) meetings like this arent meant for going out and hooning around the streets like idiots... its to go out with a bunch of ppl young and old who share one common passion... and that is our Japanese Imports!!
Lets make sure the skylines keep it that way... what everyone else does is there business (if i see anyone going stupid im off) us import drivers have a bad stigma hanging around our heads as it is... lets not proove them right!
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
