i seriously hope no idiots turn up to this event....
the next one i think we should make an SAU only cruise... wether or not it will be an official cruise or not will depend on when we get the club up and running.
id say we can organise another non-affiliated SAU forum guys cruise tho
  • Replies 299
Originally posted by lowlux
IM UP FOR IT!!!!!!!!! but inark u said no idiots can come,that means i cant come :D
but ill be good but ill just behave myself thats if all goes well and i get my car running alright
there are exceptions :(
Originally posted by RPMZ
Hope you guys don't mind an old 240z coming.............:P
if its ur 240z then i'll be damn happy so i can take some nice pics of it for me to drool over :P
wow what an great response
ermmm i hope it doesnt turn our too huge to handle..
about arthurseat being closed of??? :eek:
i hope not!!!
just pleaseeeeeeeee becareful on those twisties guy
if u feel unsafe at anytime try pulling over and let the cars pass infront of u and try stick to the back
last thing we need is any unfortunate accidents
Originally posted by inark
dont be a wuss!! all the more reason to come :P
So where u going instead?
well my bday is the 9th of jan, one of my mates is the 6th, and my other mate is the 11th... so its going to be a pretty crazy weekend.. I dont think I will be getting anywhere near the drivers seat of a car :P
Guest INASNT
i hope not!!!
All the roads to Arthurs Seat are currently closed! It might be still closed by Friday!
Guest INASNT
we havent printed out the maps as yet..
we gonna discuss it tonight and make an alternative route incase the roads are still closed
so not to worry!!
denham will u be in attendance?
Not 100% sure now as my car is going in to ICE on friday to get the cooler done
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
