  • Replies 299
I've spoken to Gerald and he reckons that one way or the other, you'll be in a shape to cruise :P
We're gonna have to kick you out at some point though coz we wanna cruise in my car and try it through the twisties :P
Originally posted by INASNT
Hes making the piping for me 2!
And as all mechanics do they wont just be working on 1 job
Guest INASNT
Originally posted by Leewah
I've spoken to Gerald and he reckons that one way or the other, you'll be in a shape to cruise :D
good to hear. now give me a discount 2!!:P
DO u have the piping at the shop already?
If u talk to gerald again can ya ask him to make sure its 2.5 inch piping!
According to Gerald, the piping will be 2.5" but it has to be fabricated. Apparently the HKS piping would suit your needs but that's up to you.
He also said that coz you have a SAFC installed, it probably wouldn't be the best idea fitting it all and going for a cruise as the AFC needs to be tuned again considering the new levels of air going into the system.
I think the best course of action is to fit the IC but not plumb it up until next week when we can get you on a dyno to tune the AFC.
If you have any questions, give Gerald a call on his mobile which is 0414 359 888.
Guest INASNT
fark that i want it all installed as i came back to work today and am 2 busy to take the car in twice!!! Also i can get the s-afc retuned on sat at race hopefully!
Sorry dude, this has now gone over my head. You'll have to call and speak to Gerald about this one.
I don't do the work, I'm just the messenger...
Guest INASNT
no prob i will talk to him!
I am more conserned about getting it all installed and running properly rather than going on a cruise!!:P
ICE is pretty busy this week, I won't be able to get my front caster rod bushes done until next Monday... :(
My corner handling is a bit crook now, you reckon it's pretty safe to go on a cruise, what are the twisties like?
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
