  • Replies 299
Hi Greg,
How did you feel when HICAS screwed up? Is it kind of getting that wobbly feeling in the rear end when cornering?
I felt that too, not sure if that's also my rear suspension bushes due for replacement, or hope not, touch wood, not the HICAS please..
Rianto
Originally posted by SS8_Gohan
sorry for putting this in here, but i couldn't pm u inark. i'll need that lift buddy. thanks!! :(
no worries...
try pming me again with ur address so i can pick u up.
hey rianto,
that is exactly how it feels -- very unstable at the rear when cornering. it wants to oversteer at the slightest excuse. eg i go over a bump - the rear kicks out. drive over a bit of gravel on the road - rear kicks out. i'd hate to see it in the wet.
i am just assuming its the hicas because i did the diagnostic and 3 errors came up, but it could quite possibly be the bushes because they are getting pretty old...i hadn't thought of them actually. i might take it to ICE or somewhere and get them to have a look at it.
Greg
Originally posted by rs73
Hi Greg,
Rianto
guys, im just writing out the route for the night and we have a couple of problems that i wanted to discuss
first off: when we say "albert park pits" were refering to Aughtie Drive on the pit straight yes?
ok, other stuff is
this is showing hints of being a big turn out cos there are several clubs that are coming, and because iv mapped out a route with with some tight twisties streets and high speed sweaping turns im affraid it may be a problem with anything more than 20 cars
suggestions people:
1. stuff it, lets take the route thats mapped
2. keep it sedate, hwys and main roads
If this is gonna be a big turnout, will the Albert Park pits hold us all? It's not exactly the World's largest car park....
Also, I think that we keep the route that you've mapped out but make sure to make it clear to everyone that noone is responsible for the actions of others and in no way does SAU condone reckless driving, speeding, etc. All risks are at the owner/driver's responsibility.
Make sure that it is clear that this is not a race and people are advised to drive within their own limits.
Just my 2c worth.
ok, other stuff is
suggestions people:
actually, i was going to suggest we meet up at the carpark further down the road where RedHeads use to be...
Melway Ref 2KE6, its a pretty big carpark, should be enough
ill keep the route, ill make the suggestion that its not a race but theres always going to be a hand full of tossers
also, authers seat carpark isnt that big either and i doubt it can hold anymore than 20cars up there
ill work something out though
looking fwd to fri night...guess it shouldnt be hard to find , considering there will be quite a few imports in the one spot !!!
i will be departing the cruise at frankston area, not a fan of the twisties, in my car at night with a heap of others just at this stage of my skyline driving experience yet hehe
see you guys there...look for me to be at the back of da pack all the time hehe
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
