I spent an hour removing one of these from an 85 MR30 lift back this afternoon and paid $ 50 for it . Does anyone know if there are rebuild kits for these and if the worm and sectors are still available . One other thing I noticed was that all three MR30's at the wrecker had worn joints on the nearside (idler arm) end of the drag link . My DR's steering box has a shocking amount of freeplay that can't be adjusted out . I dread to think what Nissan would want for a new one , if there's any left .
Any help appreciated , Cheers A .
https://www.sau.com.au/forums/topic/79402-r30-power-steering-boxes/
Spoke to the guys from datsport very helpful.
http://www.datsport.com/
Unfortuneatley the 1600 suspension and steering is different enough to not allow their kits to be used on DR. But the guy I spoke to really knows his old nissan suspension.
Oath!! Barry knows his shit very well!!!
I spoke to Peter from Sydney Suspensions (Heasmans) and he said that there is a high point in the worm sector interface and it should be adjusted to have no freeplay there (in the straight ahead position). The trouble is the further away from this point either way you go the more the freeplay there is . I can jack my car up and have about a quarter of an inch of movement in the offside wheel at full lock . Is this normal with these cars and this type of steering system ? I very much doubt the GRP A cars were raced like this .
Can anyone with experience in dinosaur era steering systems offer any solutions .
Cheers A .
Cheers  A .
The thing is becuase these cars when they raced were brand new, nothing had worn so i very much doubt that there would've been any play in them...Mine has got a little bit of play but its nothing that worries...It would be interesting to see if you got a brand new one from nissan if that has play in it or not????
I think all the trouble is in the many inner/outer tire-rod ends,drag link,pitman arm,etc,etc rather than the steering box itself? Providing the actual box isn't worn of course.Maybe there is some inherent fault in the *30's? Geez,even my old worn out KE20 coupe doesn't tram line and carry on like my HR30 used to! :confused:
Some bad news peoples , R30 Pwr Steering Boxes no longer available nor worms or sectors . Drag links are still around early and late type (changed around 10/83) but expensive at $458 retail . The race cars used one off special internals to suit that application .
That makes converting to rack and pinion sound even better. Frount runner (just from talking to some people who know Nissan) is currently series 2 280zx x-crossmember, rack and I may have the use the lower control arms and steering column.
I need to spend some time at wreakers with a tape measure.
What measurement do I need other than the size of the rack, were it sits in relation to the control arms and x-member, tie rod length, x-member size and were it sits in relation to the front wheels, track width of car, amount of left to right movement of rack/tie rods, pivot points of tie-rod arms
Does any of this make sense of am I just talking shit?
Dont know much but I am trying to learn.
Cheers
Remember that 70's cars didn't use the zero scrub geometry and hub offsets are different for this reason . To get around this you may need to cut and shut your control arms with the inner section from the Z . S12 stuff may be worth looking into (same era ) . Import Bluebird 910 with power rack could go close . Thats what I have and will use if my rally fabricator runs out of work . He once fitted manual Bluebird steering to an MR30 but can't remember which X member he used . The control arms were I think Skyline outer and Bluebird inner (cut and shut) . The steering arms were shortened Bluebird .
280zx series 2 was 82-83 I think. Yeah a few people have suggested S12 and the bloke from datsport also suggested a bluebird rack. Let me know how it goes if you go ahead was the job. What's the deal with cut and shut control arms, needs to be x-rayed to get engineer cert right?
No just a good race or rally fabricator who genuinely can weld and measure . I doubt anyone will look too close at a 20+ year old car , if its done properly it should look factory . Incidentally try running nolathane caster (radius rod) bushes and very little or no toe in . Mine has 6 deg positive caster , 1/2 neg camber and next time out from 1/16 toe to zero . Is feeling better .
oh this is nicely timed, I've been getting th DR ready for rego, dropped it in to have a seal replaced cause I don't have the gear for it, steering box was r000ted..$465 to have it rebuilt...thats just the rebuild cost nothing else. apparently they're just like nothing else around.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
