Hi All, in an issue of zoom with a celica 'HYPO77'
I think its current...
it has a SAU dno day in there at UAS?
when was it, did you guys have a thread with results and stuff.
looking for some results on a car.
thanks
Mick
https://www.sau.com.au/forums/topic/79437-recent-nsw-dyno-day-sau-at-uas/
Guest DIRTgarage
thanks
Mick
It was at least 12 months ago......we had a near stock (read:catback,boost controller, etc) GTR that made 284 rwkw
ah i thought i had seen no thread for yonks...
ok, i will still search.
I after some specs and hopefully a dyno sheet for an R33GTR running a T04R that made quote "only 301 kw atw'
I think plates are CNG something?
thanks v much guys
thanks
lol
yeah its in the Zoom mag...
which i think is the latest issue????
anyway found thread.
thanks
http://www.skylinesaustralia.com/forums/sh...ead.php?t=49366
so does anyone know Chris in the R33GTR that made 301kw that day?
mick
lol
thanks
mick
Yes
And silver-gtst it was an HKS T04R not T88
Guest DIRTgarage
thanks v much guys
thanks
what this one here
lol yeah thanks guys. defo a t04r.
anyone know CNG? or Chris i think?
Just wondering specs? like what cams and injectors?
i understand its made alot more than 300kw?
anyway thanks very much
looks nice
michael
yeah thats what i was enquiring to.
i was expecting just a little more maybe 350kw on that 20psi.
and i was thinking maybe he had stock cams. so i presume not then.
ah well good oh! what a killer power band! whooshka hold on!!! :)
any runs at wsid or anything?
thanks guys
mick
thanks guys
mick
I dont think he has, I may be wrong - I do know he hardly drives it
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
