Delema...
Car has a CD player and a cassette/stacker. now the cd shows stuff (buttons) on the TV and the volume is on the cassette unit. I has an Alpine touch screen TV all in one from my last car.
My delema is I either disconnect the CD and cassette and have 2 dins spare then put my alpine in and have 1 spare.And thats counting on it fitting because the 34 has a slopey design and the top CD player sticks out a lot. I did actually get the TV to play movies via an external NTSC source but thats a bit gay.
Whatabout the soarers I heard the TV can be converted for TV signal.
Has anyone put a unit in before?
it sort of looks like this.
https://www.sau.com.au/forums/topic/79446-34-gtrtv-use-and-stereo-installation/
Not too sure what you're asking? I have got a 1 DIN sized CD/DVD/MP3 player in the top slot and a map pocket in the 2nd DIN slot.
I have my DVD player connected to the MFD via the simple modification you can do but my DVD player can output NTSC or PAL regardless of the DVD region. But yeah I hardly ever use it.
As for converting the MFD to receive aussie TV signals i dont think its possible or worthwhile. As far as I know the TV button isn't anything to do with receiving Jap TV at all and simply a toggle switch to go from MFD to NTSC input mode for things like sat nav, and other AV factory options.
no pics on me at the moment unforunately but there are no gaps at all. You will find that all aftermarket CD players come with little plastic surrounds that can be modified pretty easily if you find that there are some gaps. The way the R34 dash is designed tho the brushed aluminium covers the gaps up quite well.
And yeah, I can watch DVD's through the factory monitor. This requires a small amount of modification to the MFD. You have to pull it apart and solder two wires to various pins and mount an RCA socket on the back of it. Very simple to do.
Link:
http://www.gtrcentral.com/technical/how_to...ideo_Signal.pdf
mine has the TV button on the cd player. is that a hassle?
Is your's a Vspec? This mod only works for MFD's with TV buttons on the MFD itself as far as i know. This is my interior before I put an aftermarket CD player in:
http://www.sewid.org/mycar/BNR34/BeforeCom...tos/photo10.jpg
That top "CD player" is a sat nav system :rofl: The CD drive is for the map CD/DVD. Its a bummer too because you cant make it work in Australia (the nav) and it kinda clutters up your dash.
One option would be to pull the unit out and get the non-nav climate control unit from Yahoo Japan auctions - then you get more space for your audio gear. I see them go pretty cheap occasionally.
hey guy! im interested to know what sort of ball park figures did it cost you's to import ur 34 gtr's?
Cheers
Well i imported mine before import duty changed to 10% (was 15%) and when the aussie dollar was a bit weaker against the yen so it's not really relevant how much it cost to import.
I can tell you tho that there are a few more issues when importing a car worth over $60k like extra stamp duty and Luxury car tax that many "import cost calculators" dont take into account, then there's compliance cost blowouts like stock parts, and brembo brake pads.
It's not easy to have a good condition no accident damaged car landed and complied under $70k - then you gotta pay rego and stamp duty...
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
