Hi guys im going to hit the dragstrip soon for the first time just after a bet of advice and an estimate on what eta to expect. maunual r33 gts25t mods to engine are in sig. suspention setup is completely stock. I will be using hankook ventus k104 tyres 235's on 17" rims.
What tyre pressure should I run with these tyres/rims?
Does the drag strip have a lot more grip then the street? (eg good street road surface.)
Can seems to launch well when you get it right to many revs wheel spin all the way though 1st to lower revs and it bogs down. does not diff hop on the street but will it on the drag strip with stock suspention?
Probably hard to say but with a reasonable driver what 60 foot times should I expect with this setup and what ETA.
https://www.sau.com.au/forums/topic/79463-hitting-the-drag-strip-1st-timer/
Going by your mods, id be looking at a mid 13 and if you hook up real well (say 2.0 60') a low 13 should be on the cards.
I always find the track to have a lot more traction than the street. Its the only time i can open it up in first gear, on the street it always spins.
Good luck
Good luck
Thanks Robo's low thirteens would be nice. Hopefully I can beet my mate in his stock VX R8 manual clubby.
Start around 25psi and heat them up nicely.  Drop them down if you are struggling for traction, but honestly i didnt find much beneficial with pressures, they just need heat.
So a burnout before a run will be benificial with these tyres? I was under the impression that it would not make any difference as its a road tyre not a slick.
its a must
when i leave my house and my tyres are cold i can spin all the way to theend of 3,rd just about but give them a couple of minutes and 3,rd is out of the question and second becames very hard and im running 255,s 17" advan smokahamas
i to want to take mine down the strip but ive got realy bad wheel hop ever since i changed wheels
cheers chris
if street tyres get out of their efficient operating temperature then you'll be driving on ice...with street tyres they are designed to operate well from cold and do not like to much heat in them....putting too much heat into them will only slow you down IMHO
They will be cold lining up for your run so putting a little heat into them shouldn't hurt.
i changed pressures from 38psi down to 20 and it made no difference, (255/40/17)
most low profile tyres have very stiff sidewalls such as mine, so even if u drop the pressures it wont do much.
Thanks can anyone using hankook k104s confirm this did it make a difference with the tyres left down? how stiff are the sidewalls?
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
