Guest gh0st Posted December 29, 2002 Share Posted December 29, 2002 hi did the gts4 r33 come with turbo or was it non turbo and the same with the r32 did it come with turbo. Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/ Share on other sites More sharing options...
Morgs Posted December 29, 2002 Share Posted December 29, 2002 R32 GTS4 was RB20DET (Factory Turbo) R33 GTS4 was RB25DE (Factory non turbo) No Turbo versions of the R33, at least from the factory Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/#findComment-115805 Share on other sites More sharing options...
rs73 Posted December 30, 2002 Share Posted December 30, 2002 I reckon R33 GTS4 is pretty rare isn't it... I only seen one in a dealer and it's even an automatic Needs lots of conversion to be done to make it a baby GT-R... As it's 4WD, the shell would probably take a GT-R gearbox too, so you can buy one if you found it anyway and then chuck in RB26DETT+gearbox and you got a cheap R33 GT-R... Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/#findComment-116149 Share on other sites More sharing options...
T0nyGTSt Posted December 30, 2002 Share Posted December 30, 2002 Nah they turn up every so often on the J-Spec etc. etc. mailing lists. All you need to do is stick in an RB25DET. It has attessa, it has the 4wd gearbox... T. Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/#findComment-116185 Share on other sites More sharing options...
Pva_Glue Posted December 30, 2002 Share Posted December 30, 2002 just give squirt of NOS... cheers joe Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/#findComment-116532 Share on other sites More sharing options...
G0DF4Th3R Posted December 30, 2002 Share Posted December 30, 2002 Originally posted by Pva_Glue just give squirt of NOS... cheers joe hmm..... a sign of things to come perhaps? Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/#findComment-116555 Share on other sites More sharing options...
rs73 Posted December 30, 2002 Share Posted December 30, 2002 Originally posted by tlai909 Nah they turn up every so often on the J-Spec etc. etc. mailing lists. All you need to do is stick in an RB25DET. It has attessa, it has the 4wd gearbox... T. Wouldn't it be better to use RB26DETT, as it could use a little bit more power n torque to counter the power loss thru 4wd drivetrain... Maybe even a 2JZGTE from supra hehe, but hybrid will be more expensive to work on as engine mounts, gearbox may not fit and need some hacking. Link to comment https://www.sau.com.au/forums/topic/7947-r33-gts4/#findComment-116585 Share on other sites More sharing options...
