Hello guys just after a little help and some feed back i have R32, in need of a new clutch. I can get my hands on either a PBR or Excedy H/D, PBR a little cheaper but not much i have 210rwkw, which clutch is better and what is the normal price on something that would suit me don't want a button clutch. I am getting the Excedy for about $480 and the PBR for $400 just need to know one should buy thanks
https://www.sau.com.au/forums/topic/79474-pbr-clutch-vs-excedy-hd/
Im getting an exedy HD clutch put in tomorrow, ill let u you know how it goes. Part no NSK7056HD. Try ABS, they gave me a pretty good price for the clutch, but i ended up getting one at cost price through a friend of a friend..
My car is pretty stock though, probably 130kW at the wheels, so the power comparison wont be that suitable.
The PBR is very poorly built (well all the dead ones I have seen died prematurely).
My last PBR clutch died after 50,000 km. The friction plate was barely worn, but the pressure plate crapped itself.
I don't know of any1 that has had good experiences with a PBR in a performance car.
Hey if anyones interested i had my exedy HD clutch installed today. It feels and works great, took a little while to get used to but i couldnt be happier. The install cost me $250 including machining of the flywheel.
Looking at the standard clutch compared with the exedy HD, the springs on the friction plate are much smaller and the diaphram finger things are not as strong or well built.
My std clutch was worn down to the rivets on one side.
PS i think there is one for sale in the for sale thread at the moment for $400
cool thanks man but i picked one up for $360 brand new with Excedy H/H, rpm brass button pressure plate and bearings 12month warrenty getting installed saturday $150+$30 for machining of flywheel
They are great prices, where did you get them from? Whats a H/H?
My clutch kit was $375 as I had a father of a friend who knows someone who worked a Exedy once or something. Best price i could get apart from that was about $450.
please tell me how much u got it for
i also have an Excedy HD clutch and i think its pretty good, doesnt make any weird noises and love it cause u cant slip it much
ive ran around today looking for a clutch for my GTR.... some of my friends are using the EXEDY ORGANIC CLUTCH an they say its the best thing that they have come across an it cost around $450 to $550
check out BGT clutchs in dandenong its a crapy little work shop, but i went to EXEDY today an they said that BGT clutchs, should give a good price since the buy in big bulk
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
