Well its on again. Unfortunately my car was not ready for the private track day on the 11/07 but it will certainly be ready for the normal S.A.S. on the 16/07. Can't wait to get out there again and test out the new goodies.
Hopefully we can see some more people there. For all those that can't make the mid-week days here is your chance. The weather is nice and cool, there is no excuses, lets go have some fun! :wassup:
https://www.sau.com.au/forums/topic/79485-1607-qr-saturday-afternoon-sprints/
Wats the go with these sprints? I am intrested but have no idea on time, cost, etc. I sent jlnewton a PM but got no reply...
http://www.queenslandraceway.com.au/
if you to get the track license for $55. Its valid for a year. Then its $95 for 3 sessions on the track or $75 if you prepaid at least one day before the event.
We usually get there around 10am.
Sorry for working full-time and spending all Thursday night fitting a new set of extractors to the mini. Look it up, all the info you need is on the QR Web page, its just an open to the public day not a privately organised day.
But. . . . we usually turn up around 11 ish to try and get one of the undercover pits, I have to renew my 12month license which is about $55 I think and the sprints have gone up from what I have heard, $75 prepaid and $95 on the day????
You need a current license, at least long sleaves and long pants, and a helmut (you can hire them there). And then just get ready to have some fun! :(
NA_R33, it will be interesting to hear your comments on cheaper but wider rubber as last time I bought tyres they convinced me more expensive thinner rubber would give better grip due to the compounds etc.
Ill be sure to let everyone know how good they are after the auto hands it too jason... nah jk's. But yeah was only out there 2 weeks ago with the old yoky's on the rear. Before even hitting the track, the car has never hooked up as hard out of corners with the 265's.
Looks like we're kinda organised. Car is currently in at mechanic (his reaction after seeing the figures from it's current wheel alignment was not good - hence it's staying the night). Should be back fri arvo, and all is set for a sat blasting.
Also bringing out a mates "power cordia" - with special smoke screen function ready for use. Hope the line holds together though, as the cordia is a trailer only job (and finally confirmed that the line does fit on the trailer :) just as well).
See you there JLNewton - can't wait to see how well your GTR peddles.
Hey, Dave. Actually bailing on this now as of yesterday. Have been invited to attend a track day at Darlington park on Sunday. Can't do both days and the Darlington park track is heaps more fun ;):) :)
Shall see you guys at the next one!
well we made it to the sprints and had heaps of fun, especially on the last free runs...but that was a bit naughty :chairshot teehee
best time Noddy got was a 1:00.8400, and plenty of consistant 1:01's
Was good to meet all you guys too. :Pimp2:
heres some pics http://www.boostcruising.com/journal/entry...7/yes/4323.html
and, http://www.boostcruising.com/journal/entry...7/yes/4324.html
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
