hey all,
im looking for a R32 GTR to buy, ive been test driving quite a few, but i have some issues and questions that maybe someone knows something about??
- should i steer clear of a rusty underbody?
- is slightly bent weld seam undercar a problem?
- is slightly dented/bumped chassis rails a problem?
- one car crunched slightly going into 5th after pushing it a bit in 4th what does that mean?
- one has had factory ecu tuned in japan and is running a catless O2 sensorless exhaust...?
- one has aftermarket clutch and makes a strange noise from front/transmission when taking off under 2500rpm?
- are things like the door and window seals, easy/expensive to replace?
- is the shrunken inside window seal(along bottom of window) easy/expensive to replace?
- is that damn bubble they all get in the dash infront of the passenger easy/expensive to fix?
thanks for any info
Dan
https://www.sau.com.au/forums/topic/79496-buying-a-gtr-problems/
rusty underbody -> yes
bent/dented/bumped chassis rails -> yes
crunching into 5th -> worn synchros on 4th and 5th gears are common on the gtr box. it could be as simple as doing an oil change on the gearbox, or it may be fully stuffed
catless exhaust, no o2 sensor? wtf ? that cant even be registered
strange noise could be just the noise a multi plate clutch makes, or it could be a problem with the front diff/transfer case ?
door/window seals are easier to replace than most other thinsg :D
bubble ?
hey all,
thanks for any info
Dan
Ok I will answer you questions as you typed them:
rust is not good. if there are a few little bits that' not uncommon and if treated wont pose a problem. if there is lots, or it is more than just surface rust, then probably best to keep looking, or really consider all the aspects of the car
I assume you mean the seam that is just inside the side skirts. this is not a problem. they mostly get flattend from being put on hoists, jacked up etc. no big deal.
again, providing the car is still straight this is no big deal. can be caused by improperly placed/sized jack stands, being lifted with a forklift or a jack. or can be caused by hitting something (ie big rock or gutter). slight dents and bumps appart from looking unsightly are not a problem. just make sure it doesn't start to rust there.
could be a couple of things, could be worn synchros, could be some debris in the box (which would indicated something else may be broken), could just be you shifted too quickly, could be that the clutch wasn't full dissengaged (which could be you or could be a clutch problem) it's hard to say
ok, I would say it does have the 02 sensors. they are in the dump pipes just after the turbo. the sensor you are most likely thinking off is the cat temp sensor which does nothing other than trigger a warning light to warn you not to park in long grass! it's the one that is located in the cat. having no cat means you will have to buy and fit one. have a jap tuned ecu could be good or bad. most of them seem to like to run very rich mixtures and high levels of ignition advance which could be bad. they tend to give a very responsive feeling car on stock boost, but can cause detonation once you wind the boost up.
I have no idea mate. is it just squel? some brass clutches do squel on take off.
not really. I think the seals will be a few hunderd dollars all up. but this is pretty common to most R32GTRs. even the newest 32GTR is now more than 10 years old.
apparently you can inject glue into it to glue it down. if that works then it would be a cheap fix. if not it will need to be re-skinned. not so cheap.
thanks for the quick replies guys!
the 5th gear shift is definately not me, i did it several times, but appeared only when making a higher rev change. when just cruising it was fine.
-strange noise from front/transmission...
this was kinda like a rattle, but a solid rattle that shuddered the car a little, (as opposed to a tinny exhaust problem type rattle), it sounded like something was loose or broken, almost as if the clutch wasn't lining up properly or something like that.
it also seemed to make the chassis twist a little? or at least made the floor under my feet move a bit?? if that makes any sense?!
cheers
The problem with buying any cars that have any sort of chassis damage is that the chassis can creak, or bend because it is slightly warped or damaged.
I had one with some 'slight' damage to one of the rails, and let me tell you, it made a helluva creaking noise whenever i went over a speed hump :D
hmmm thats an interesting point, i didnt think to attribute the noises to accident damage, only mistreatment. if only i could foot the bill for a r34 i wouldnt have these silly issues!
well they're 2nd hand too so i suppose i would....
also...
ive noticed a lot of r32's have this gap at the back on the parcel shelf behind the top of the back seat, and the seat is generally a bit loose... is this just because they havent been fitted back on properly? i dont know why they would be taken off in the first place!?
and the wind noise at 80kms+ is this common in all R32's? i noticed the little window shield visor thingy around the door frame seems to stop it from happening, but if its removed, or isn't there at all, can the wind noise be stopped??
dan
also...
yeah mine has the gap between the shelf and the back seat. As they are not a split fold design the backrest hangs on these little metal hooks. These are so pathetically weak its not funny, they fold up if you look at them wrong.
If you mess around with them enough times trying to get it right like me, theyr'e never the same hence the gap....
Mine was removed to run stereo cable etc so its probably the same. Get dark window tint and you can't see it. Its not a problem from the inside....
AS for the wind noise, yes mine is very noisy, I have messed around with the window alignment trying to get it right and that's what's caused the wind noise. Maybe they need to be re done? nothing major though. You'll find most pillarless cars have a fair degree of wind noise.
As for the dents and such underneath. You have to remember these are not new cars anymore so some accidents (little ones like clipping curbs) of bottoming out will more then likely have happened. My R32 has a few little dings and stuff underneath, its pretty common. I wouldn't worry unless the damage is severe. The car is old so it may or may not creak regardless. Mine does not. These cars are not cheap for no reason! they're oldies but goodies.
Mine also has a litttle bit of rust i'll be fixing. Again, an age thing, if its small and fixable its still worth it, mine has no other rust other then a 50 cent sized piece right behind the drivers front wheel about a foot back on the underside.. Several I've seen also have it....
thanks bazelinerz!
the gtr i had a look at had a fair amount of rust,
the fuel tank was bubbley all over under the paint with rust, the whole exhaust was rusty, the whole underbody was rusty, the chassis rails and weld seams everything... and had a spot peeping through the top of the side skirt in the door jamb...
i think i'll give that particular GTR a miss....
re bubble:
that's a neat idea with the injection of glue, but how do you know that behind it is something appropriate to be glued? ie. how do you know that behind there is a piece of plastic, and the material hasn't split in half? the bubble on my passenger side is pretty hard to push down so i'm not sure anything like glue would hold for long. i try to ignore it.
re bubble:
I have the bubble too! Are you saying it's not supposed to be there? Nah it's just one of those things like the broken air con vents...
:confused:
spot on about the gap for the back seat. Remember it needs to be taken out if anyone is putting a stereo/wiring etc in.
As far as the wind noise - thats caues of the stock mirrors. My last car (32 GTS-T) had this however my GTR doesn't because it has Ganador mirrors.
also...
dan
Its called the "whether strip".  Try Nissan to confirm prices
Lucien.
Cheers dude,
I rang Nissan and they said there are 5 versions? WTF? they can't get prices they need to ring Japan. Pathetic.
I'm guessing I'm gonna need a part number for them to have half a clue what I want.....
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
