as everyone else has said, less resistance = easier free flowing = wind up quicker
make the exhaust less restrictive, good tune. good dump and front pipe and hiflow cat
yeah a bleed valve will slow it down a little as its always bleeding regardless of pressure
https://www.sau.com.au/forums/topic/79508-2-laggy/#findComment-1449110
im about to do the samt thing
have a VL high flow lined up
can u tell me the specs of the turbo?
also how many PSI are u running and how much power are you getting out of it?
the turbo is a VL hi flowed with steel wheels front and rear dunno all da exact specs as i braught second hand and i forget easy. but yeh once u get to 4grand the power comes on hard havnt dynoed yet but its got krazy pull now! compared to the standard rb20 turbo i had on there and i am still only running 12psi for now!!!
but the problem is the whole 4grand thing lanching is a bitch!! top end is good as bottom end well u can decide 4 urself i think!!!! no good
https://www.sau.com.au/forums/topic/79508-2-laggy/#findComment-1455326
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
