Just interested if anyone else has come across this problem of the oil squirter hitting the piston at BDC?
I've just installed my first piston & it seems that it just hits the injector ,no.2 is worse, that was as far as i went, getting ready to machine the pistons to suite.
I would like to see approx 1mm clearance around the squirter, as it was they would have been tapping the skirts & the bottom side of the piston near the knuckle.
The clearance that Arias has supplied seems to be deep enough just 3-4mm offset forward to were they should be. :goddam:
Engine hadn't suffered any trouble in the bottom end,was pulled down due to a severley blown head gasket.
I've tried relocating the squirters,with the small amount of play that is available on the locating lug but can't seem to get enough clearance.
Rb26 standard size arias pistons 86mm
Standard RB26 rods
Any help would be appreciated.
https://www.sau.com.au/forums/topic/79509-arias-pistons-hitting-oil-squirters/
http://www.skylinesaustralia.com/forums/sh...ead.php?t=52879
Have a read of that thread, especially proengines reply on page two. I had exactly the same problem, proengines described why it happened and solutions to fix it.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
