Time for a new turbo for my RB20. It's more than likely been covered many a time before but i'm new to site and in my random browsing haven't come across it yet!
I'm after something as easy as possible to fit to the car, leaving the car as drivable as possible (don't want the turbo spooling 2000rpm before redline like some other setups i have seen), and something that will leave me a fair bit of headroom for the future!
Thanks!
https://www.sau.com.au/forums/topic/79546-what-turbo-for-rb20/
  • Replies 45
I'll agree with the above regarding the HKS GT2530 but don't dismiss the GT2535 either !
The thing I found with the 2530 was that you smoke the tyres too much just trying to get the power down ( not really a problem for most I guess :) ) But when I fitted the 2535 that problem went away as the bulk of the power moved up in the rev range. I tiny bit more laggy than a 2530 and doesn't kick you in the butt like the 2530 but it does provide very smooth power all the way to the top ( even after you've done a whole bunch of mods ). Still, if you're only planning on normal bolt on mods the HKS GT2530 is prol one of the best hair dryers around for an RB20DET. By the way, it MUST BE A HKS !! Not a garrett GT2530 !! They are not the same animal.
My 2 cents :)
hi-flow the RB20 turbo, not a huge difference between the RB25 turbo and the RB20 turbo, just a slight size difference in the impeller wheel (can't remember if im thinkin of the right thing or not). Anyway, there's another option, not sure if u'd get as much bang out of it though, can anyone clarify this matter?
How would a turbo from a VL perform on an RB20?
I ask as I have a GTSR with the standard fitment T03/TO4e which I think would be similar in specs to a standard VL turbo.
Yes, the technology is from the dark ages but I gather they are also cheap to pick up for the budget concious (sp).
I currently have 235+ rwkw with all support systems at 16psi which is reached at about 3900rpm.
  MattSR said:
How well would a GT30 be suited to an RB20 with cams?
I reckon it'd be a good match if the RB20 could handle ~8500-9000 rpm or so
Cheers,
Matt
From memory, R31nismoids GT30 equipped RB25 sees about 16psi at about 4,000rpm with a tuned length exhaust manifold and all support systems.
The RB25 is 25% larger in capacity than the RB20 so in theory it would see 16psi 25% later in the rev range at approximately 5,000rpm.
So I guess, if funds allowed and you wanted to take that route a GT30 might be a decent match for a no holds barred 9,000rpm RB20.
  mr_rbman said:
why is the hks 2530 so much better than the garrett item and is it just the exhaust housing that is bigger on the 2535hks?
Wheel AND Housing profiles are different between HKS and Garrett ( even though Garrett makes the parts for HKS ). HUGE difference in power delivery ( IMHO ).
As for the physical differences between the HKS 2530 & 2535, I honestly never stopped to look nor did I even ask. :bonk: It was a spur of the moment swap as both myself and the other guy wanted what the other had performance wise so we just swapped turbo's and got what we wanted :thankyou: .
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
