If you were to upgrade the turbo on a 33 (or even running standard turbo) how much boost could you safely run?
The main reason I ask is because a mate said that the head gaskets on the 33's are crap and anything over 1 bar of boost and they can easily pop.
Is this true and is it common with both series1's and series 2's or did Nissan rectify this problem on the later series?
I would be looking to make about 250@wheels
Thanks
https://www.sau.com.au/forums/topic/79566-33gtst-how-much-boost-can-you-run/
Thanks
There is nothing wrong with the standard head gasket people often go to a thicker head gasket when running high boost to lower the compression of the engine. From what I have heard 250@wheels should be fine with standard gasket with supporting mods injectors, fuel pump, ecu, turbo ect. Run no more than 10psi with the standard turbo as rule of thumb as the ceramic wheels are week. As for how much boost can I run if you are using an after market turbo it depends on what turbo you are talking about what mods you have ect.
agree with munna, you don't really want to push your standard turbo to hard i have heard you can run them safely 10psi and if you want to push it 12 - maybe 13 but thats pushing it a little. If you go the after market say a ball bearing as i have with all the bolt on bits eg. fmic, ecu, pod, injectors, fuel reg and pump i think you can push them up to about 16 - 18psi. Not 100% i am no expert just what i have heard on hear. At the monent i run 16psi on my R32 and thats pretty safe with out open the engine up for the other goodies
ohhh mate , easily run my car at 50psi on standard turbo
bloody goes great guns!!!
haha nah how bullshit was the game tonite !!!
i have to work tommorow ****!!
nah standard turbo man on r33 gtst run 10psi max to be safe, i have heard pplrunnin 12 and 15 but ya know depends how ya drive, and what ya do.
my car is tuned to run 8psi cause anythin over it ****in goes no where,
and is it 250 rear wheel kilowatts or horsepower.
cause horspower would be doable with a standard turbo
but kilowatts, mate you'll blow up the turbo b 4 gettin to there safely !!
anyway im gone, im takin my car down the quarter next weekend, with the manual conversion in
see how she goes! hope it doesnt fall apart !!
THannks ,
Baaazzz!!!
250rwkw is not do-able on a standard turbo, injectors and management.
I was simply refering to the fact the RB25 will make that power without having head gasket issues, which was asked about above.
Who would waste time with a standard turbo in the hunt for power anyway. :D
I have a standard turbo, with and apexi pfc FMIC, and full custom exhaust.
Car is running 12psi, been like that for about 12 months plus, and I am always on boost (hence me fueling up alot :cheers: ) turbo is fine.
The head gasket is not what you have to worry about its the ceramic turbine in the stock turbo that is the weakest link when it comes to boosting up the psi. I would run 10psi to be safe but have heard still some people blowing there turbs at that pressure so it up to you if you want to risk it. Best bet if you want that power figure is to get a new turbo or high flow it to be safe. This topic has been discussed heaps on the forum do a search.
i run around .9-1 bar on my stock turbo.. after 140k's no shaft play on turbo and wheels arent warped neither are the housing. I run it on .5-.6 bar to put around town tho. around 1 bar is only for short spurts. I have some sort of engine management to keep the AF's in a great line :Dj:
agree with munna
Yeh true... but on another subject... 'Your Signature'
Dude... Although 210 Rwkw sounds correct.. I'm pretty sure your not getting 729Nm of Torque God dam!!!! lol Unless your running 24+ pound boost 'in which you wouldn’t only be getting 210 rwkw'
so stock turbo aside.....the first part of the quiestion was "If you were to UPGRADE the turbo on a 33 how much boost can it hold"??
this is something i'd be keen to hear about myself, being i'm currently running a Hi-flow turbo on my 33 @ 18-20 psi....how far can I go before the head gasket gives way? i know short one off dyno runs an stuff it can handle a fair bit off boost, but what about with full boost being used for greater amounts of time...like say circuit racing or drifting?
:cheers:
Ive been running 12-13psi boost on stock turbo for the last year and still has no shaft play and never had a hickup.
I do have HKS Cams though so weather that has contributed to its longevity in pissing off exhaust through a straight through 3.5" turbo back with high flow cat *shrugs*
But i just bought a Highflowed TO4e :)
So if it blows i will let yous know how much boost i could squeeze in :cheers:
Not reading it wrong buddy on my dyno graph it has 2 lines kw and toq and in the top right corner it tells me max rwkw and it tells me max touque so hate to dissappoint you but i do have 729nm. I have a pretty big turbo on my car would that help such high reading it is a GT30 ballbearing the guy that i bought it off said it is good for 650hp+
I'm not car or torque expert I just thought this doesnt sound right out of my common sense. A ford FPV GT makes around 550 Nm T at the flywheel I believe, this is from a 5.7L V8 which is very torquey & i think it makes around 300 kw at the fly also. Now lets guestimate you have around 270 Kw (210 rwkw + 60kw drive train loss) at your fly on a 2L engine only running 16psi. Like I said, I dont know what the exact equations are for torque figures but I certainly know that 729 Nm T! is a absolute shit load for a 2L engine running under 20 pound. I mean stock Mercs V8 Supercharged cars make around this figure. A Holden Monaro with a Twin Turbo kit makes around 850 Nm T, so a 2L running 16 pound making 729 Nm T just doesn’t sound right to me.
Anybody else who actually knows more about torgue figures please but in? Where SK when you need him... He'd set things straight. 'regardless whos right or wrong'
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
