I have just purchased a new set of chrome rims. Prior to this I had magnesium rims so they were fairly resiliant to the elements.
What are some suggested products to protect and clean chrome? Suggestions?
Is it worthwhile buying some VHT wheel clear coat and spraying it over the top to protect? Any experiences?
Cheers!
-Alex
https://www.sau.com.au/forums/topic/79576-protecting-chrome-rims-advice/
steer clear of gutters.... lol
I used gold class on my old ones and they still look new.... Have not even rotated for 3 years but yeah they look good as my coffee tables with a sheet of glass... LOL
and yes its true i do have a polished turbo as a paper weight for the car mags... The mrs hate it and it disappears weekly but i keep bringing it back
