Hi all,
as the title reads, i hear an odd noise when the clutch is in. It's hard to describe, so i'll do the best i can. It sounds like it's coming from where the gearbox joins the motor, and it's like a rattling/whining type of sound. My next door neighbor had a listen to it and his first impression was a throw out bearing (not sure of spelling). But then he asked if it had an aftermarket clutch, which it does - it's a OS giken twin plate clutch, and then he said he's not sure what type of noises they make.
I can't drive it on the roads as it is unregistered so i don't know what noises it makes whilst driving.
Any help would be great... thanks in advance guys.
Regards,
Shaun
Twin plates rattle a little when you push the clutch in (disengaged).. the plates are loose so the vibrations from the engine/input shaft can cause them to rattle a little. It could also be your thrust bearing if its whining a bit. Nothing to worry about.
Thanks Andrew, appreciate that.
Yeah my mates HKS twin is damn loud.. My triple however is nice and quiet.. Just a little rattle.. Typical though my 180SX had a loud input bearing on the input shaft of the gearbox, that car made noise in nuetral with the clutch out, this one makes noise with teh clutch in, can't win...
