Updated prices with postage and insurance from US to Aus included. These prices are in $AU with GST and customs duty included. Postage extra.
Here are a few of the gauges from the Autometer gauge range if the gauge you're after isn't here then pm me and I'll add it to the list.
Cobalt C2 Series:
3 3/8" 10,000 RPM ATM-7297 $310
2 1/16" AIR/FUEL RATIO $135
2 1/16" BOOST 30 In Hg/30 PSI MECHANICAL $130
2 1/16" OIL PRESSURE ELECTRICAL 0-100 PSI $145
N.B. 90DEG SHORT SWEEP
WATER TEMP ONLY AVAIL IN IMPERIAL FAHRENHEIT
2 1/16" NITROUS PRESS ELECTRICICAL SENDER INC 0-1600 psi $315.
Cobalt Series:
3 3/8" 10,000 RPM ATM-6297 $310
2 1/16" OIL PRESSURE ELECTRICAL 0-100 PSI $140
2 1/16" NITROUS PRESS ELECTRICAL SENDER INC 0-1600 psi $315.
Carbon Fibre:
3 3/8" 10,000 RPM ATM-4798 $220
2 1/16" AIR/FUEL RATIO $120
IN DASH 3 3/8" TACHOMETER 0-10000RPM $220
IN DASH 3 3/8" SPEEDOMETER 0-190KM/H $340.
2 1/16" BOOST 30 In Hg/30 PSI MECHANICAL $110
2 1/16" OIL PRESSURE ELECTRICAL 0-100 PSI $125
2 1/16" NITROUS PRESS MECHANICAL 0-1600 psi $150.
PHANTOM SERIES:
3 3/8" 10,000 RPM ATM-5897 $175
2 1/16" AIR/FUEL RATIO $110
2 1/16" BOOST 30 In Hg/30 PSI MECHANICAL $95
2 1/16" OIL PRESSURE ELECTRICAL 0-100 PSI $105
2 1/16" WATER TEMP ELECTRICAL 40-120C $100
2 1/16" OIL TEMP ELECTRICAL 60-170C $100
2 1/16" NITROUS PRESS MECHANICAL 0-1600 psi $160.
SPORT COMP SERIES:
3 3/8" 8,000 RPM ATM-3991 $175
2 1/16" AIR/FUEL RATIO $105
2 1/16" BOOST 30 In Hg/30 PSI MECHANICAL $90
2 1/16" OIL PRESSURE ELECTRICAL 0-100 PSI $100
2 1/16" NITROUS PRESS ELECTRICAL 0-1600 psi $315.
ULTRA-LITE
3 3/8" 10,000 RPM ATM-4497 $185
IN DASH 3 3/8" TACHOMETER 0-10000RPM $190
IN DASH 3 3/8" SPEEDOMETER 0-190KM/H $335
2 1/16" BOOST 30 In Hg/30 PSI MECHANICAL $100
If anyone wants me to add other gauges in each range pm me and I'll add them.
2 5/8" gauges are available on request. Generally add $5.
Black Autometer 2 1/16" Gauge cups ATM-2204 for $25.
Carbon Fibre Autometer 2 1/16" Gauge cups ATM-2121 for $75
Carbon Fibre Mounting Cup
Postage is $6.50 - $9.50 dependent on your location in Australia and the number of gauges you are ordering.
I will be placing orders with my contact every month so will be able to provide a reliable supply of these.
Cheers Chris
  • Replies 72
All of the Autometer range are available including:
Carbon Fibre
Cobalt2
Cobalt
Lunar
Phantom
Sport Comp
Ultra-lite
Z-series.
Prices vary so post specific requirements and I'll reply with pricing.
Cheers
Chris
How about just posting up what u can get and for what price. It saves alot of back and forward post asking the same questions and gives everyone an idea :thankyou:
I didn't do this as there are approx 28 pages of gauges in the Phantom range alone and I didn't want to create the thread from hell.
Or check out this link:
http://www.bugsandbuggies.com/vdo_main.asp
Please note that these prices on the website are in $US add approx US$5 for shipping multiply by 1.32 for exchange rate add 15% import duty then 10% GST.
Chris
Either the Cobalt or C2 range will glow blue they glow very much like the tachos.
Pillar mounts like these:
95-98 Nissan Skyline GTR Right Hand Drive - Single Pod for 2-1/16 inch Gauges $45 for the single pod or $55 for the dual pod but the dual pod is on backorder so could be unavailable for months.
Or another option again:
What time frame are people looking at for their gauges. I have had quite a few requests for gauges from people and am looking at setting a deadline for deposits to be in by so I don't keep the genuine people waiting.
Cheers
Chris
Guest
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
