Hi all, I am a new ceffy owner :P Got a few questions for you guys
1) Why does my ceffy have two throttles in the engine bay? My mate said it may have had cruise control but i couldn't find anything on the dash.
2) Is the ceffy actually wider than the sil? What offset is required for wheels to be flush with the guards?
3) Where can I get a kit?
and... 4) SR or RB20 for the conversion :( (I lost my lisence for 6 months so I got about 5k and 5 more months to make it into something decent ;))
Thanks for your help,
Chris
https://www.sau.com.au/forums/topic/79637-ceffy-question/
Im not looking for huge power as I have already lost my lisence once and the temptation would be even greater with a 25, just looking around 150-170rwkw which is quite possible with a near stock rb20, maybe with a tb25 turbo or something. That 5k wasn't justr for the engine btw :(
LoL, you will piss that in no worries.
Just go an rb20 then. Say aftermarket management. Go the rb25 turbo so it makes that power easier. FMIC, gearbox if yours is still auto etc.
Theres ya 5k...
Then spend whatever else you had on decent suspension. Springs that work (ie not too hard) all your sway bars, castor, camber, bushes, then get stuck in to the brakes etc. Have the whole package.
https://www.sau.com.au/forums/topic/79637-ceffy-question/#findComment-1450832
Yeah if you want response go the sr20 with the s15 BB turbo. too_much was pulling 190rwkw with his sil80 I believe.
You'll need a FMIC, fuel pump, injectors, tune ... plus engine plus gearbox.. hmm I think done right you could pull it under $5k.
I'd go the SR ... I would never ever put a rb20 into a cefiro.. if it alreayd had one in there then no worries.. but why would you put one in ? :D
https://www.sau.com.au/forums/topic/79637-ceffy-question/#findComment-1451375
That's 197.7rwkw thankyou very much!.. on 12psi with factory ecu, injectors and afm!
will be interesting to see what it does on 16-17psi
https://www.sau.com.au/forums/topic/79637-ceffy-question/#findComment-1451558
and... 4) SR or RB20 for the conversion :) (I lost my lisence for 6 months so I got about 5k and 5 more months to make it into something decent :D)
Chris
3) For a kit there are a few guys on NS.com (sponser section) selling kits.
4) i'd go a RB25, or SR20, just depends on what you want. SR for dorifto.
https://www.sau.com.au/forums/topic/79637-ceffy-question/#findComment-1452336
I was under the impression rb was:
+more powerful stock
+designed for the car
++cheaper
-older
-less torquey
sr's:
+newer
+torque
+lighter
+more aftermarket parts
-more expensive
-less base power
Won't be using the car for pure drift, maybe an event evey now and again. So many people seem to be against the rb :)
https://www.sau.com.au/forums/topic/79637-ceffy-question/#findComment-1452373
hey when you go from rb to sr did you have to change any of the mounts? did you buy them or fabricate? how is it done? also how much of a pain would it be to get your warning lights and speedo etc working? perhaps too much could enlighten us?? :)
https://www.sau.com.au/forums/topic/79637-ceffy-question/#findComment-1452375
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
