Busselton
As some of you know I went down to Busselton for a bit of break for Xmas. Had a great time as if you think your car gets attention in Perth goe down South, everyone has a look:) There were 2 other lines down there (a black series 1 R33 and a gunmetal R32 with a frontmount,bov and a R33 GTR wing which looked stupid) so I had a few people waving at me and had a little run with the R32.
A friend of a friend down there has just bought that GSR "WRXETA" and I went for a spin in that, no power till 4,000 but after that...wow, he didnt launch it with me in it but I dont doubt its best time of 11.6 on streetlegal race rubber.
Also got some fuel consumption figures for the GTR and they impressed me, about 9.5 - 10L per 100K's. It helps if you reset your ecu before going for a long drive though, makes the ecu forget all your spirited driving :P
Also it is Trev city down there, saw 4 diff. Maloo utes, a TS50, couple of clubsports and a senator or two.
Anyways that it, what did everyone else get up to?
Ryan.
https://www.sau.com.au/forums/topic/7964-busselton/
  • Replies 60
almost dying on Perth Heat!
almost T-boned my best mate's Brand New V8 Commie. :lol:
Broke up with gf :P
Got nice pressies from everyone
Got rejected from girls at the paramount quite a few times...:P
Got Drunk and done few stupid stuff with bottles
Cleaned my room!
I drilled a hole on my car for CAI. -just need few PVC piping.
Had fun with sunday morning rain!
Perth Gory won the PPowers 2-1
I am stuck at work boring.....
cheers
Joe
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116081
all it deserves
Broke up with gf :P
This a new one or the one who was using u to make her ex jealous
Not me
Lol losing ur touch buddy
U go girl
atleast u don't have a nightshift on newyears eve
cheers
Joe
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116106
cheers
Joe [/b]
LOL night shift! man that's sucks...
anyway at least you can just pop in to sprit sound bar when you finish! :lol:
cheers
Joe
ps.it's new one I had great time of 40 days of happiness...:P
cheers
Joe
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116111
Ahhh, Busselton in summer :P
Hot chicks in white bikini's on the beach is all I think of when someone says "busseeellttooon" *sigh*
Which kinda reminds me of a really good idea: A busselton run down south for the day would be a good outing for SAU methinks.
I heard about the success of the last overnight busselton/stay thing, sounded really fun :P
I dunno, how about it guys ? who's up for an event like this ? while the weather is nice ;)
-Kym.
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116114
Carl has had some dramas with the GSR since buying it off Toby and was quite pissed Toby took off the mags, seats, stereo, cold air intake and was suprised to find that the oil catch can is held in place by double sided tape.
I'm not saying he isnt happy with the car, far bloody from it, just he thought he was getting more :P
But I'm sure they both got a deal that was more than satisfactory in the end.
He needs to ask Toby about the launch control and water IC spray as he thinks its hooked up to the windscreen squirters 'cause they dont work !
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116544
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
