Hey guys i dont currently own a skyline but was looking into getting one......the two im looking at are the r33 and r32's gtst.....now my mate has a mkii falcon xr6turbo.......simple........i want to beat him.......the r33's look better (with the 400r bodykit which id put on) but the r32 is lighter if im not mistaken......ontop of the actualy price of the car i was not looking at spending more then 10-12k on mods to beat him......hopefully get into very low 13's or higher 12's on da 1/4....if this is not possible i guess i'll have to go EvoII
Thanks guys
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/
  • Replies 46
have to start of by saying metallica is the best band in the world
secondly, if ur mate a an XR6T you really wont have to spend a lot of money on either a r32 or r33 gtst to beat it. get an exhaust, cooler, fuel pump, injectors (or fuel regulator), chip the ECU and upgrade the turbo and you will hammer him. after all this you will have heaps of money left
and the debate of r32 vs r33 has been going on for ages. it all comes down the personal prefernce
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450912
The R33's run low 13's when an exhaust, fmic, powerfc and a bit of boost.
Some have even managed a high 12 sec pass with a well sorted rear end.
Grab your self a decent R33 with an exhaust and possibly fmic, drop in a powerfc and it will be running the times you want.
Providing you can drive that is. lol :D
Those XR6T's can launch pretty hard off the mark.
If you can't drive you'd better go the 4wd.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450929
Well i was thinking of if i were to get one....(r32 or r33) put in exhaust, fmic, sard injectors, fuel regulator, to4 turbo (dont know which spec yet but one with good mid-high torque/power with steel ball bearings), and either chip or full stand alone...plus cams and valve springs seeing as the head makes all the power.......also how much approx is it to rebuild an rb motor with lets say forged rods, pistons and balanced crank etc
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450938
screw gettin a Rex, ull get hammered shitless on the freeway by an xr6 turbo, plus not have as much cash left over for mods to try to keep up... dont want that. But as it was said, if your a bad driver the 4wd will help from the traffic lights and will give u a large advantage over him.
Get whichever you prefer looks wise as both the 32 and 33 will deliver fine especially if you plan on putting 10k + into power mods into the beast!! You'll be running low 13s easy as in both cars.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451152
Thanks guys
do you see the word freeway in there?
no
do you see the word 1/4 in there?
yes
will the rex beat a xr6t on "da 1/4"
yes
what car R33 v R32?
I prefer R32.
the money on mods that you say you want to spend you could build a wicked engine (doesn't have to be an rb20... go read the rb30 thread up the top of this forum)
that will destroy many a car on "da 1/4"
xr6t = 1700+kg
r33 = 1350 kg
r32 = 1260 kg
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451457
Providing you can drive that is. lol :cheers:
What cubes said.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451542
Then just get a big, heavy stick.
Seriously, decide what you want, then do it. With $20k to spend on a car and mods, youll be able to kill him.
My opinion, to really piss him off, get an R31 GTSX import (still eligable under the now 16 year rule) with an engine upgrade (either rb25 or rb26).
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452042
Look at tradingpost!!!!!
Why are you bothering getting a GTSt if you already have the plan to mod it. Start with a GTR.
R32 GTR's going for around 23K with a few goodies, saw a black one with N1 turbos and a claimed 250KW @ wheels (something like that).
Get something that already goes fast so you know what you are getting into the day you buy it.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452133
I am with psybic just spend a little more on buying the car and less on the mods a R32 GTR goes for around 22k - 23k with a few goodies and then if you have to just add powerfc, wolf 3d so you are able to fine tune then a fmic if doesn't have one. Little bit of boost you will eat him alive that way you get a better car in my mind and you might only have to spend 3 - 4k instead of your 10k
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452192
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
