Mounting Apexi RSM & S-AFC II
Hey guys,
Just wondering if anyone is running an AFC and RSM and where it is mounted. Ive got an R34 GTT and strugglin tryin to decide where to mount em. Thanks for your help.
-ice-
that looks really nice... i guess the glovebox would be a good place for the AFC but kinda defeats the purpose installing an RSM there...
-ice-
true that I have seen them on the steering colum just infront of the dash they look ok they but you would need to hide the wires somehow so it looks neet.
  • 1 month later...
Something a lil different that the guy in the shop laughed at when I suggested it. I wanted to be able to quickly mount it anywhere didn't mind about the cables dangling as I wanted to quickly remove it when I got out the car to the glovebox. I was originally going to use the velcro everyone has suggested but I had another idea.
I wanted something with a ball joint so u could swivel it in any direction. I ended up getting a suction rear view mirror, not a large one but one that was about the size of my blitz sbc id3 and power meter controllers. I cut it to size, very lil had to be cut off depends which one u buy and stuck the displays on with the usual high bond double sided sticky tape. I then position it whereever I like, usually on my R33 its just to the right and down from my clock it suctions their wickedly, has never fallen off and is quick to put up and down again. I also at times stick it to the windscreen.
For a total cost of $10 its a lot cheaper than the apexi stands which can only swivel one way a lil limited for my liking. Everyone that sees it cannot believe it only cost me $10 cos it looks so good and easy to do!
Well hope this gives u some ideas!
 Share
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
    • I wonder if there is much to tell without knowing where the bolts where bought from. If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that. Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all. It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that. A bit depressing but the reality is you really have to be weary of where and how you buy stuff
