ok once again i have bought something i no longer need. Heres the run down
For sale is my Hawk EC21 EMS. head on over to EFI hardware to check out full specs. basically it is a complete management system like microtech, autronic, motec etc but much cheaper because it's australian made.
it tunes in 125rpm increments and has a higher resolution tuning map than any other ECU out there (perhaps bar megasquirt) for very fine adjustments. it does closed loop for good fuel economy also. i only know information on the rb30 setup but it can be used on any engine.
i will include with the package:
- Control unit
- Full loom to suit Z18T 4 cylinder (just so you can steal plugs off it if you're using it on an RB30) which even comes with the three critical relays so you can just wire up about 10 wires into your existing loom and it will run.
- Water temp sensor, ECU is calibrated to this. you can calibrate your standard RB30 sensor fine also if you desire.
- Air temp sensor, calibrated also
- 3 bar (30psi) map sensor for big boost applications
- Delco TPS which you may or may not use, you can calibrate your standard TPS to work fine if you desire
- ECU-computer comm cable
- CD with wiring diagrams, software and a full manual which describes every detail about the functions of the ECU
- A base map which is suitable for a modified VLT running standard injectors. this will cut tuning times drastically saving you dyno time and money. all cold start and accel enrichment details are in there already.
it is a very versatile ECU and i have played with the software which is very easy to use, and has a live-screen dashboard readout which is extremely useful.
looking for offers around $750 which is what i paid for it.
pm me or reply here, or ring me on 0421859091
cheers
shanon
https://www.sau.com.au/forums/topic/79652-fs-stand-alone-management-software/
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
