Nismo 400R rear pods for R33
in reality the new engine was a swap alot because it was brand new vs 3 years old and the other one needing a refresh after wtac anyway but... the 2.8 is obvious capacity etc and will do current power more easily and add some responsiveness not that that was really lacking the limiting factor with all this atm is injectors (ID1700s at 4 bar base) and turbo (precision 6780) literally being maxed out at bang on 1000hp as thats what the system was designed to do, so to go more need injectors, turbo and maybe even intercooler but i know a guy that like his power and will see how this all unfolds it is a rwd drive on an 050 tyre though and i am just a complete amateur so among other things the ability to drive it becomes a consideration also
Not hard. It is a factory option for the car. If you are planning to do the swap yourself and you have to ask if it's hard or not, then it sounds like you will find it quite challenging to do. Does the budget allow for the purchase of a RB25DET gearbox at the same time? Life will be so much easier if you can swap both the motor and box together, and it's not like your saving yourself any money either, you WILL need the bigger box in future. By doing it now you will save time, money and you won't find yourself broken down at the most inconvenient time in the future. -
Thanks. That's helpful. Definitely easier to get ones for a Silvia. And this confirms my suspicions that they would work too.
Hi. After a 4 long/short years i wanna ask. Just ask cuz i know it would be a ALOT work but. https://3gspares.co.nz/collections/engines/products/nissan-r34-skyline-rb25det-neo-turbo-5mt-complete-engine-motor-package-104-400km-gt-t I found this engine...it looks like it has all the things you need to for the swap. It looks clean and in very good condition How hard would it be to swap instead of RB20DE NEO(factory 5spd manual) I know the gearbox is weak but it should just plug n play for a while no? I have better fuel pump(mine went bad) and brakes are from GTT. Iam just asking around to gather info. Only considering this cuz i know these guys and this engine IMO is completed package for swap. Thanks :)
