hey guys...
my GTR fmic came in the mail today from Mark from centreline which is all good!
but... as u can see in the pics its a little rough... will it still work ok? or will i need to get it repaired?
https://www.sau.com.au/forums/topic/7967-guys-is-this-fubared/
Inark,
If it's just the fins that are dented then it shouldn't be a problem. Just grab yourself some long nose pliers and straighten them out as much as you can, to allow the air to flow through.
If you don't put mesh infront of the cooler when you fit it you will get that happening all the time from rocks and other crap on the road.
Cheers
Compared to that, mine is an absolute mess but still holds pressure no problems...
Had coloured smoke pumped through it and none came out so it;s all good. The fins are made of super soft metal that oftens snaps off when straightening so b careful. I broke heaps of mine but it still works so don't stress too much.
Adrian.
Originally posted by BROKEN
your local radiator place can pressure test it for you.
nice carpet.:P
lmao... thats one of the couches in the kitchen :D
oh well thats ok then... i'll get it tested this week then... time to get some piping made up :)
Morgs -
the cooler itself cost me $70AUD but the postage cost 32000yen which is a bit of a killer... Mark had it in his garage for 6 months for me til i could pay for the shipping but had to clear some room so sent it anyway. Hes a good bloke to deal with. He sent it on the 25th and it got here today, the 30th
Yes all R32/33 GTR coolers are painted black stock. The 34's are polished however so are silver. Yes the front has been cleaned on that one. The black doesn't affect the cooling.
Light damage on the cooler doesn't matter as long as most of it is in tact. The fins aren't as improtant as the tubes so make sure the tubes have no punctures. Mine is similar but has a few squashed fins.... will be u for sale soon if anyone is itnereted.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
