Hi everyone,
Wanted to get my 32 GTR re-tuned for more boost & timing, but i dont want to drive all the way down the coast to PITS again. What are peoples experiences with GTR's and tuning in Brisbane??
I have heard that Archie at Mazfix does a good job....has anyone used Brisbane Tuning & turbo at Woolloongabba??
Also Mercury, Charlies Motors, APC??
Cheers
Francisco
https://www.sau.com.au/forums/topic/79694-tuning-in-brisbane/
Just had my GTR tuned at Brisbane Tuning & Turbo Centre, they fixed my problem straight away. Can highly recomend them, just don't listen to the mechanics as they bag your car while they are working on it!! :) But John has a fair bit of knowledge about GTR's, he has an old Zed car with an RB26 transplant (putting out 547HP at the wheels), his son drives a GTR and one of the mechanics (the one bagging the wheels on my car) has one too.
DO NOT GO TO BTT
i had some work done there and they over charged, were rude and did shit work
something as simple as getting a boost gauge installed
sold me a shit gauge, tried to charge me to fix it (even though they sourced it and installed it)
also coudlnt diagnose simple issues (tps needed resetting and timing adjusted)
i woudlnt trust them to work on my push bike
will never go there again
mercury did some good work on my bro in laws car and i know lots of others that have had good work done there
chapman and chapman used to service my car and always did good work also, but were exxy
One lame experience for a boost controller doesn't slam a workshop.
it was more than that
car was in a bad way after i had my custom plenum and intercooler done
went there to get it sorted
for 300 bux, the car drove out of there worse than it went in
i asked john about enginemanagement when i was there
he looked me in the eye and told me that powerfc would NOT be able to be used on my engine due to the custom throttle body and plennum, and that i would need to go microtec or a more expensive option
even funnier when i went back to get the POS boost gauge fixed (that i was going to be charged again for) that john tried to sell me a powerfc (he also blamed my plennum for the boost gauge issue, even though thats how the plennum was when THEY installed it)
went to motsons, and for half the price, the car was running how i wanted (simple things like resetting tps and the timing was WAY out 32 degrees advanced or something)
btt had done work for me before and was ok, and it was why i went back there despite many people telling me of their horror stories
i should have listened to them
I GOT HAD
im seriously considering going to small claims to try and get some of my money back considering what i paid for and what i got
SPOOKS_SKYLINE
if u have such a big issue with my workshop then instead of posting a reply on the forum bagging BRISBANE TUNING u should simply give us a call and sort your issue out with us.
prehaps john was confused when discussing ecu option for your car, as for your issues with our work, i could not say because i did not deal with u or your car.
Our knowledge on nissan imports is quite extensive, so u should not question our experience.
U SHOULD NOT GO AROUND PUBLICLY BAGGING A WORKSHOP WHEN CLEARLY U HAVE NOT SORTED YOUR ISSUE OUT WITH US CORRECTLY.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
