most likley this is happening cous you don't really got any resistane on first gear it's like reving the engine without any gear in you don't get any boost because the engine dont have anything breaking it. and without any resictaneyou cant get any pressure. its like blowing in a hose quite easy but if you plug your finger half way in to it it gets harder to blow.
So does it feel like you are getting boost in first?
Maybe the guage isn't reacting quickly.
You always should get boost in first no matter what.
In first however with some cars you wont hit full boost like you do in other gears.
For example I have boost set to 16psi and in first i will be luck to hit 15psi.
Boost also tends to taper off towards the end of first as the turbo has trouble keeping up with the airflow requirements that increase so quickly.
Where as in the higher gears the turbo can really spool up and get the air moving.
Hence why 3rd gear is the passing gear.
Guest DON91E
Wow your getting this too??
Well im running a turbosmart stage 2 boost controller,
and when iv boosted it to 10psi, in first i only get up to like 7psi but when i change into 2nd it shoots up to 10 and so fouth with 3rd 4th,
So why can't i reach max boost in first gear?
Donnie
Dave
So does mine.
Up to 14-15psi in first gear is good, anything over and first wont have it.
Probably a little to do with first gear spinning up and having no load on the motor though.
Wait until you start trying to push 15+ psi in first gear. :P
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
