most likley this is happening cous you don't really got any resistane on first gear it's like reving the engine without any gear in you don't get any boost because the engine dont have anything breaking it. and without any resictaneyou cant get any pressure. its like blowing in a hose quite easy but if you plug your finger half way in to it it gets harder to blow.
So does it feel like you are getting boost in first?
Maybe the guage isn't reacting quickly.
You always should get boost in first no matter what.
In first however with some cars you wont hit full boost like you do in other gears.
For example I have boost set to 16psi and in first i will be luck to hit 15psi.
Boost also tends to taper off towards the end of first as the turbo has trouble keeping up with the airflow requirements that increase so quickly.
Where as in the higher gears the turbo can really spool up and get the air moving.
Hence why 3rd gear is the passing gear.
Guest DON91E
Wow your getting this too??
Well im running a turbosmart stage 2 boost controller,
and when iv boosted it to 10psi, in first i only get up to like 7psi but when i change into 2nd it shoots up to 10 and so fouth with 3rd 4th,
So why can't i reach max boost in first gear?
Donnie
Dave
So does mine.
Up to 14-15psi in first gear is good, anything over and first wont have it.
Probably a little to do with first gear spinning up and having no load on the motor though.
Wait until you start trying to push 15+ psi in first gear. :P
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
    • Oof. Could be worse I guess. I suppose they haven't put any effort into ally suspension parts or CF panels, seats, etc. So they could probably pull about half of that back out of the car. Not like a bunch of other EVs that already have CF everything and roll the scales at ~2t.
