Just curious if theres any intention to be a putty road cruise again this year? Came along last year with Aurora and Shell and was awesome :rofl: (until we hit a wombat and destroyed a brand new HKS FMIC on the way home... :P)
From memory it was around this time last year it was held.
https://www.sau.com.au/forums/topic/79781-putty-road-cruise/
  • Replies 46
You could do it twice... or drive down and meet us, and cruise back to lunch, as most people usually go their own way after lunch...
But to answer your question... Yes we are going to be doing it again this year... Date is tentativly set for 17th September. (Saturday)
Nik you should bring your car this time...it's more fun being a driver than a passenger!  :)
I intend to, it was broken last year which is why I couldnt bring it. You going to come again Shell? Might try get a few of the other guys up from Canberra too.
i went down the putty at 4am one day, it was unreal....no farmers or trucks mosying along.... could see the headlights around the corners if someone was coming... and it was very very cold that morning... made for a very spirited and tyre shredding adventure.
d-d... monkeykplunk and i are thinking of doing a putty cruise in august sometime champ.
also anyone that doesnt know about the putty... get the new speed, it has a review in it. it also mentions the cops in singleton, they are shocking.
cheers
Linton
Putty road > take this at speed and it will certainly show you the benefits of an IRS, low profile and wide tyres.
Very windy (pronounced wyndy)... it's alot more than just that.
It does have a few nice long straight stretches as well.
I am even thinking an over night option... which you canberrians might be interested in! :P
Yep, was talking to Ewen (Aurora) about it the other day. I think our plan is head up on the Friday afternoon, stay at Windsor on Friday night (we did that last year), cruise Saturday and stay with you guys up the other end Saturday night, head back home on Sunday :P
yeah Nik I'll be going again most probably!
definately stay the night before again, I'll have to see about the night after...although it's such a long crap drive home after the cruise...hmm could be a good plan..
should i book you the stinky room again? haha
Excellent... yeah, if im driving ill definately be staying Saturday night, wasnt a big fan of the drive home straight after the cruise.
To be blunt, that room was fu**ed :D Haha (*stops whinging*) but yeah, staying there again should be sweet, was nice and close to the shops and not too far into the city so im all for it :P
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
