I need the following
Rio for front bar for R33
R33 GTR FRONT GUARDS <------ NEEEEEEEED
Preffer SE Queensland but will pay for freight.
Updated 1 October
Still required :(
Edited by Slide
https://www.sau.com.au/forums/topic/79800-slide-needs-for-r33-lots-required/
I have the parts but in melbourne
Air conditioning radiator (condensor): 260
Radiator:265
Oil pump (me thinks)(Power steering pump): 175
Air conditioning compressor: 180
Control arm for steering (left hand side): I have complete steering rack 220
Radiator support bars from chassis to bottom radiator support (both): 80 each
Front of chassis inc top radiator support bar and front left 1/4 chassis: I have a complete half cut shell for 450
Air conditioning preasure unit with pipes: I think you mean bottle If you buy a few thing i'll throw it in the deal
And oil line pipes to go from the air conditioning compressor to the oil compressor
(pretty much the whole aircon engine setup)
Radiator Fan output shaft from water pump: I think you mean clutch fan 100
Skyline33 could you please get a rough idea on freight costs for the radiator and aircon radiator delivered to Banora Point 2486. (NSW)
What condition are they in?
People please email pics to [email protected] (please keep dialup safe)
Radiator $200
A/c condensor $180
p/s pump $140
a/c compressor $150
rad support bars $100 pr
33 1/2 cut shell $300
air con lines and fan FREE
can orginise freight cheap
Woot cheaper
How much to get the half cut shell to Banora Point 2486 Dsturbd?
It looks like i will need the steering rack aswell now so how much people?
And also the mount on the side of the block that has the ac comp and power steering pump bolted on it.
Karma is just a word
Bang.
My tie rod/steering arm was slowly unscrewing its self by stripping the thread eventually broke off leaving me with no steering on the left side leaving me with a big splinter in the front of the car from a 3 tonne log.
Damage is minimal. the only structual damage is the radiator support and steering rack bent.
Shoot the person that sent the msg for me hows that sound :)
Hey aaron try a importer see if you can get the front cut after the motor has been pulled out going to be a lot easier & quicker/cheaper then trying to get parts from here there & everywere, just a idea bud
good luck with it
Yeah ive been speaking with Just Jap/RMA/Rollin down here but atm they are short on them and wont let me cut the front off.
Its looking more economical to leave it to a panel beater to play with magic.
Be interesting to hear how much it will cost me for the half cuts from SYD MELB OR BRIS
Any info appreciated.
Thanks guys as soon as the chassis sorted i will be buying the parts.
haha she gets upgrades now for not being a write off
will be contacting your suggested today cheers OZ
getting full 400r bodykit and fibreglass bonnet.
lucky i have all the new part contacts :P
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
