Ok recently i was pulled over and fined for not indicating x 2. i dont have enough points left to take this lightly.
Here's what happened....
I was in right lane.
Van infront of me decides to do u turn at specific "NO U-TURN" sign, indicate at the last minute and leave their ass hanging out in the lane.
To avoid braking heavily and possibly receiving a rear end hit i checked the lane beside me, it was clear so i changed lanes, went around the van and back into the right lane...weeoooh cops pull me over.
I explained the situation, still got the fine and if it weren't for my permits, i woulda got a yellow as well.
I dont even remember if i indicated or not, the fact is it was a last minute decision because of the sudden change in what was a smooth continous traffic flow.
Anyone been through something similar? Is there a way to settle it out of court?
it was your fault , you were following to close . you should always leave enough distance behind the front car to stop if there is sudden braking . Swerving and changing lanes is a never a good idea , lots of people swerve into an opposite oncoming lane and have a head on collision.
youve got to break in your lane in time to not hit the car infront , same for the people behind you . If not you were following to close .
you have no chance of fighting it and winning . the out of court settlement is to pay the fine .
You may be able to get it lessened, theres no harm in trying. Write them a letter explaining the situation (if u have a clean record even better) just be polite but formal in your letter and hope for the best. Its worked a couple of times in the past for mates of mine and i myself have gotten away from a fine by explaining the situation.
Its not worth Fighting it, I'd say based on the above comment her record is not "clean"
Simple fact is if you needed to swerve to avoide the traffic in front you were following to closely. Chances are you got off lighly with a charge for no indication. You could have been charged with careless driving or worse
One of the few remaining benefits of being in Australia is that you have the right to take this to court if you want to.
They cannot give you a greater penalty - only what you have been charged with plus court costs. If you do elect to take it to court, you have the right to request the officer's statement that will be presented. Make sure that you do this as the version presented is often very different from your recollection (or reality?).
Good luck.
In addition, in order to preserve you license, you can advise that you will be contesting the matter, and by the time you get a summons you should have (hopefully) points back so you can pay the fine and any admin fee and still have a license.
At any time before you actually appear in court you can pay the fine and the matter is finished.
It is no substitute for good driving, but simply a means to keep your license and learn to keep it clean.
Edit: your points are not deducted until you pay the fine.
her32 it is worth a try to write them a letter, just explain the situation, its not gauranteed to get you out of it but its worth a try. simply writing them may save u a bit of money, and if it doesnt work there was no harm in trying
There was at least a 3 car space between my car and the van infront if me.
This road is not safe for u turns, hence the sign that says "no u-turn"...
it doesnt matter if theres a 50 car space , if you cant stop in time and have to swerve into another lane , your to close your at fault .
It doesnt matter if they guy decides to just stop in the middle of the road for no reason , if you hit im from behind or commit an offence to avoid hitting him from behind its your fault .
Sorry im just telling what is in the road code .
Have to agree with the others, if you had enough time to brake, or do as you did & check your blind spot, you had enough time to indicate. Try your best as far as you want to go, but I don't fancy your chances. They will also take into account the fact you already have a decent amount of points against you.
Let us know what happens anyway, good luck with it.
don't bother trying to fight it, i lost my license 2 weeks ago (not for anything stupid i might add just accumulation of 12 one pointers........) just take what you have been given, if it makes you lose your license so be it...... trust me I couldn't afford to lose my license either as I have work,studies and other commitments but hey shit happens and I did....... Don't bother applying for E plates if you only get a 3 month ban either as by the time you get to court to explain why you should be given the E plates the three months would have been up already :) Enjoy transperth as it's my New Best Friend too :rant:
I've argued the point. Never won but, always worth arguing a point when your about to lose your license for points.
Then by the time you actually have to pay the fine you get enough points back :)
My longest time to postpone a fine was 18months and coming in a close second was 13 months :)
Good luck :)
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
