Just need a hand with this situation.
Put a 25 turbo on my RB20.
I have put a hose from wastegate to the manifold and t'd in a GFB bleed valve.
The turbo is running sweet and at 5psi.
When i try to wind the bleed valve up it is having no affect.I have double checked and it is facing the right way (arrows to the wastegate) but yeah no increase.
Is this stuffed controller or will it have something to do with the setup for wastegate.
https://www.sau.com.au/forums/topic/79832-boost-wont-increase/
Try it without the bleed valve for a start.
Also put your rb20 actuator on the r33 turbo for an extra couple of psi.
Your mods will also have an effect but i wouldn't expect the boost to be held that low by stock intercooler/exhaust.
I have put a hose from wastegate to the manifold and t'd in a GFB bleed valve. [unquote] The hose goes from the wastegate to the turbo not the manifold.
RB25 trubo comp cover doesn't have a nipple to hook the boost signal up to like the rb20 turbo.
Either way the boost drop between the plenum and turbo wont be so excessive to cause the problem, if anything it'll be making the turbo work a touch harder.
If all tests fail try replacing your spark plugs.
I had iridium plugs in mine, threw on a hi-flow turbo and the thing wouldn't boost over 10psi. After 2-3hrs of fault finding on the dyno, my mechanic decided to change the plugs to a V-grove type, (there was nothing visibly wrong with the iridium’s) the next run saw boost hit 22psi and making power. Dropped boost back down to 17psi and started tunning :P.
In all honesty i do not know :). I was running about 12psi on the std turbo, then we bolted up the hi-flow turbo and would not go past 10psi, but made about 180rwkw (same as std turbo @12psi) As stated b4, we went through ALL other possibilities b4 we decided to try the plugs.
This may not be the case for yourself, just stating what i experienced, hence why i said; "If all tests fail, try replacing your spark plugs."
as a test, why not take the line off the wastegate and go for a drive slowly.
see if boost goes over the 5-6 psi you've been getting.
since nothing is there to open the wastegate, it should have unlimited boost so do it carefully and slowly.
at least this will test if your wastegate is stuck open or not.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
