Just need a hand with this situation.
Put a 25 turbo on my RB20.
I have put a hose from wastegate to the manifold and t'd in a GFB bleed valve.
The turbo is running sweet and at 5psi.
When i try to wind the bleed valve up it is having no affect.I have double checked and it is facing the right way (arrows to the wastegate) but yeah no increase.
Is this stuffed controller or will it have something to do with the setup for wastegate.
https://www.sau.com.au/forums/topic/79832-boost-wont-increase/
Try it without the bleed valve for a start.
Also put your rb20 actuator on the r33 turbo for an extra couple of psi.
Your mods will also have an effect but i wouldn't expect the boost to be held that low by stock intercooler/exhaust.
I have put a hose from wastegate to the manifold and t'd in a GFB bleed valve. [unquote] The hose goes from the wastegate to the turbo not the manifold.
RB25 trubo comp cover doesn't have a nipple to hook the boost signal up to like the rb20 turbo.
Either way the boost drop between the plenum and turbo wont be so excessive to cause the problem, if anything it'll be making the turbo work a touch harder.
If all tests fail try replacing your spark plugs.
I had iridium plugs in mine, threw on a hi-flow turbo and the thing wouldn't boost over 10psi. After 2-3hrs of fault finding on the dyno, my mechanic decided to change the plugs to a V-grove type, (there was nothing visibly wrong with the iridium’s) the next run saw boost hit 22psi and making power. Dropped boost back down to 17psi and started tunning :P.
In all honesty i do not know :). I was running about 12psi on the std turbo, then we bolted up the hi-flow turbo and would not go past 10psi, but made about 180rwkw (same as std turbo @12psi) As stated b4, we went through ALL other possibilities b4 we decided to try the plugs.
This may not be the case for yourself, just stating what i experienced, hence why i said; "If all tests fail, try replacing your spark plugs."
as a test, why not take the line off the wastegate and go for a drive slowly.
see if boost goes over the 5-6 psi you've been getting.
since nothing is there to open the wastegate, it should have unlimited boost so do it carefully and slowly.
at least this will test if your wastegate is stuck open or not.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
