Hi everyone. (this may be a crappy thead i know) Just thought id post this see if i get any reply's from the best forum on earth. So got this summery sheet from the workshop. Could you plz tell me your opinions on the list.....eg what should be fixed asap etc what you think of compression what items might mean what)
thanx (will leave some of the dumber items off eg.window washers not working correctly etc)
No. #3 cylander burning oil - s plug white
Rocker Gasket leaking
centre tailshaft universal has movement
top of g/box wet with oil
timing belts last done?
coolant/brake fluids nedd replacing
top radiator rubber mount broken
RH top of suspension arm knocking
left rear suspensioin arm was loose
high hydrocarbons on idle - camshafts?
compresion 1-140 2-150 3-125 4-120 5-155 6-120
umm yeh couple of others not worth listing etc
any input appriciated (yes im going 2 get leakdown test done but broke atm) (also how much u reckon to get valves reseated?) (along with fixing all on list)
nothing major there bit concerned bout comp tho but yeh just thought id put it out there
btw heading 2 japan soon land of the gtr....cant wait!
peace all
umm yeh (camshafts apparantly) pods..highflow turbos apparantly...full exhaust umm.. hks intake bits thats roughly it as far as (engine) goes
(car seems to be running really well atm tho....was running there for a while shite but changed plugs and taped coils thing and seems to of made a good difference
running standard boost and has about 50,000 on clock
;) plz dont say rebuild time....i just shat myself
(apart from compression what tell tale signs are there that a rebuild is needed????)
others?
surely its not rebuild time just need valves reseated?
Those compression results are far from great, id steer clear of anything with more than 10psi variance across cylinders. Get a leakdown test and see if it tells you whats breaking inside the engine. The burning oil on cylinder #3 isnt a good sign either.
Cam cover gaskets are normal, most GTR's I see have a dribble of oil from the rear of the cam covers. All the other things just sound like normal wear and tear. As for the high hydrocarbons, we started my car with no cat on and Tomei 260 in/ex cams, and it sent the machine off the scale at idle. EPA might hate you for it though...
Normal wear and tear doesnt sound too bad, they are old cars but engine wise id be putting money aside as I wouldnt be suprised if the engine let go some time soon.
if its all so bad then why the hell didnt the workshop tell me to stear clear instead of saying yeah its good car with minor faults...so i bought it!! dont get me wrong i love my car but if the engine goes in the near future then im gonna be P I S S E D how do i payout on workshop if it does die?
It is very easy to produce a bad result with a compression test not done quite right. Have a leak-down test done before getting too excited.
This doesn't make sense. Burning oil = black oily plug.
No biggy...gaskets relax with age...re-tighten screws
R32GTR tailshaft does not have a centre universal joint....it has a CV joint and some movement is normal because it is rubber mounted.
Almost certainly the shift lever boot has perished. Simple job to check and replace. Boot costs about $30.
If you don't have any history on the car, timing belt should be one of the first things on the list....recommend doing the water pump at the same time as well as the idler/tensioner bearings.
Again, unless you know the cars history, change all fluids (I would do them regardless)
Any loose or suspect suspension parts should be repaired/retightened/replaced as required. Close inspection of brake condition is a also a must.
Not good dude....
If the car had 50 on the clock and has these problems didnt you think this was strange.
The compression tests do not look good at all. The suspension and rubber dammage tells me straight away that this car has done more the 50k.... With out even looking at it....
Drive it like it is now..... Sell it and buy another one..... Next time get a forum member to go with you to check it over... Im sure there are a few in TAS who would help ya out...
All these old RB26s are timebomb (I'd suggest you're naive if you don't agree)
I'd look at a leak down before you decide its rooted
Steve's reply is fairly comprehensive
PS welcome to the world of the GTR time to introduce it to your wallet :rant:
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
