As new Garrett GT42/45
66mm GTcomp wheel,
GT45 turbine and shaft,
1.15 turb housing
5 inch inlet comp cover, 3 inch welded alloy outlet.
5 inch v band + stainless stepdown pipe from 5 to 3 inch for the dump,
as new 5 inch inlet Unifilter
braided oil supply line (full steel fittings and teflon hose)
Laser cut 12mm mild steel flange for manifold construction
Brand new (unused) 4 wire oxy sensor
800x500 heat wrap material (silver backed fiberglass matting-unused)
Turbo good for 800hp and 25psi++
See thread-
http://pforums.company-hosting.com/....php?t=67192 256
The turbo has completed 1 dyno session and 6 passes at the strip-all on fresh full synthetic oil.
Turbo made 321rwkw on 14psi, pump fuel, through an auto with super rich mixtures (wasn't even starting to breathe yet!). Clean as a whistle.
Should boost on a 3.0L by around 4000rpm-but ideal for a big 6 or V8.
Only being sold as something even bigger has become available.
Asking price-$1350 ono (including shipping by TNT-or delivered to you personally if in Adelaide SA metro area)
[email protected]
0438 803 567
You woudn't be interested in swapping the comp cover and backing plate
with the smaller .66 roller bearing cover would you, plus obviusly a reasonable
cash difference, make the turbo cheaper again for anyone that wanted it.
cheers
angela
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
