Can anyone suggest any/all causes for pinging as my tuner is is going crazy.
I am running a Microtech MT12 on BP ultimate and have a ping at the 5500 and above, he retarded the timing still there, changed timing belt still there, removed the cat no change, tryed a different crank angle senor still there. I cant think of anything else to change if youz can it would be greatly appreciated.
https://www.sau.com.au/forums/topic/79841-annoying-pinging/
Carbon hot spots on the pistons or maybe a single faulty fuel injector not injecting enough fuel under high pulse widths from being clogged.
Thats the only reasons i can see why it would ping consistantly regardless of timing settings etc. Both these situations are rare but very possible and a hard to identify.
Sounds like your mechanic has checked all the other basics. Fuel pressure, Inlet temperature, cam timing, exhaust back pressure etc etc?
Really need to know a bit more about what setup you are running to help more?
https://www.sau.com.au/forums/topic/79841-annoying-pinging/#findComment-1454145
I have new walbro fuel pump, new filter and malpassi regulator.
180bfj20det- I am running 1bar boost, standard r33 turbo, large FMIC with 2 1/4" piping and no blow by we can find, will check for oil today. Thanks
RB30-POWER will check plugs again but injectors or carbon sounds like likely suspects to me will endeavour to check these.
Thanks for your replies
https://www.sau.com.au/forums/topic/79841-annoying-pinging/#findComment-1454778
