Can anyone suggest any/all causes for pinging as my tuner is is going crazy.
I am running a Microtech MT12 on BP ultimate and have a ping at the 5500 and above, he retarded the timing still there, changed timing belt still there, removed the cat no change, tryed a different crank angle senor still there. I cant think of anything else to change if youz can it would be greatly appreciated.
https://www.sau.com.au/forums/topic/79841-annoying-pinging/
Carbon hot spots on the pistons or maybe a single faulty fuel injector not injecting enough fuel under high pulse widths from being clogged.
Thats the only reasons i can see why it would ping consistantly regardless of timing settings etc. Both these situations are rare but very possible and a hard to identify.
Sounds like your mechanic has checked all the other basics. Fuel pressure, Inlet temperature, cam timing, exhaust back pressure etc etc?
Really need to know a bit more about what setup you are running to help more?
https://www.sau.com.au/forums/topic/79841-annoying-pinging/#findComment-1454145
I have new walbro fuel pump, new filter and malpassi regulator.
180bfj20det- I am running 1bar boost, standard r33 turbo, large FMIC with 2 1/4" piping and no blow by we can find, will check for oil today. Thanks
RB30-POWER will check plugs again but injectors or carbon sounds like likely suspects to me will endeavour to check these.
Thanks for your replies
https://www.sau.com.au/forums/topic/79841-annoying-pinging/#findComment-1454778
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
