you have to upgrade the brakes for a non turbo engine?
It has more power than the stock RB30E or whatever is in it, even if you don't have to, it's probably smart to do it.
I know you have to do it for the turbo, but I'm not sure if its compulsory for the NA, I just assume it is.
I've put slotted rotors and ebc pads in the stockies, guess i'll have to suck it and see
awsome choice of brakes, i will invest when i can afford, just make sure you bleed the line and put in some high temp fluid, you probly allready know but my mate upgraded and hyrolocked cause the fluid boiled and crashed now he knows to compression lock :S
My mate just got his car engineered after putting a forged 4g63 into his lancer sedan... so now its like a GSR mock up.
He didnt upgrade his brakes, and it still passed engineering easy... his car had gone from like 80kw NA engine to like 180kw turbocharged engine...
So its really 'if' you feel like doing it... you dont HAVE to do it like some people say if your only increasing its power by a little bit.
When the rb20det goes in mine, brakes wont be upgraded, because its not needed.
Dayne
your in SA
you have the idiots at regency to deal with
they don't care about engineers certificates, they consider themselves the foremost experts in the ADR's.
go speak to them to ask if THEY will approve it
Tell me about it, trying to avoid going there.
I spoke to a cop on the phone today and he told me to just go for it and drive the thing. Just go to the rego office and change the engine number over.
you shouldnt even need an engineers certificate... the engine is smaller than the original. its also cleaner and quieter... just get a blue slip done to have the engine number changed.
too easy, good choice of engine!
cheers
Linton
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I dried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4     I did the other 5 in less time than I fluffed around with the first one. I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the casing. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I overcome one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
    • Even back in the day, some importers were renowned for bringing in crashed cars, giving them a quick touch up + respray and making them look mint
    • No new updates from the op after covid, hopefully everything is ok...
