Although the GTS-4 handles better than a GTST
But what is handling? I think handling is the ability to change your line mid corner, move the car around under brakes. Perhaps dive too deep under brakes and still get away with it without plowing off the road. Those are the sorts of things i associate with handling, the chuckability and that sort of invincible feeling a car can give you.
Now whilst im feeling invincible its the grip thing that sometimes lets down the handling. And your right in the wet there is no comparison, but in the dry, given the same tyres the GTST will have the same grip but with less weight to carry.
Out of slow speed 2nd gear corners perhaps more traction...but then again how many RB20 powered cars have problems in 2nd gear...not many:)
How is awd helping me coming out of a 3rd gear corner at 80km/h. At 160km/h in 4th gear how is AWD helping me. In my eyes its just another 60-70kgs im carrying around...and id rather a crate of home brew in the back:)
And how is the extra weight helping handling...weight is the death of handling, so you cant say it handles better because its AWD. The argument could be put forward it has better traction...but anyway each to their own...we all like different things from cars, so like i said test drive both and make up your own mind:)
Somone will know for sure the weight difference, it may only be 70kgs, but surely its where the weight sits?
As for my wheels, it will brake my heart to part with them, but the rubber has to go, its only going to harden in storage, the wheels will keep though if they dont sell:)
For an "expert" opinon check out these two threads. They did a comparasion on the autospeed website.
R32 GTS-T - http://autospeed.drive.com.au/A_0853/page1.html
R32 GTS-4 - http://autospeed.drive.com.au/cms/A_1289/article.html
As for handling, handling comes down to how well a car pulls through a corner. The GTS-T will pull through a corner much more quickly due it lower weight and its centre of gravity being much more pulled towards the rear of the car. Where the GTS-T would fail is if the tyres begun to lose grip and this is where the 4WD overcomes it. But retain traction with good quality tyres and the GTS-T will pull out just as quick. One thing you also have to realise is that the GTS-4 is not a constant 4WD system like the WRX's or EVO's and therefore doesn't have the same sort of failsafe driving manner that is present in the constant systems.
GTS-T better.. weight less.. chuck.. fun..
Basically I agree with what Baz is saying above..
my gts-t weighs 1270kg.. and there is about another 50kg I can strip out off the top of my head.. the 89/90 models are the lightest of the lot..
GTS-T's don't have much of a problem with losing traction at the front with decent tyres. In fact with the less weight over the front and in general, may have better turn in and give you bit more exit speed out of the corner. Depends how you like to drive I guess..
"Better" & "Fun" are very subjective words - Each to their own, I say. All Skylines are good - Hopefully there is enough info in this thread for the thread starter to make a decision :)
hey,
just as a little bit of personal expierence, i had a run against a stock'ish gtst, i owning a gts4. i had my mate in the car (we're both about 6'3 and weigh a bit') and the two in the gtst looked rather average size. it was a rolling run from about half way through 2nd, and his car just kept slightly pulling away.. nothing drastic, but i just cant help to think it was just the added weight of the 4wd stuff that held us back.. ;)
in the wet though, traction is bless. my mates rb20 powered vl is shocking, where as ive had to nail it to catch up to speed on a merging lane and apart from some initial loss, i pulled hard and barely broke traction in 2nd. id imagine a gtst just sliding side to side as it struggles to remain stuck on the road.
shaun.
This is where people misunderstand. There is a difference between handling and grip. Best example, WRX. WRX's grip, but handling needs work on.
Of course the GTS4 will grip better. But take the GTS4 out on the circuit and it will suffer more understeer than a GTST. Weight up front you can't help. But here is where it becomes subjective. Some prefer their car to understeer while others prefer oversteer.
Like Roy, I've become a purist. RWD action for me because I'm a control freak and don't want computers thinking for me.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
