well i have a link in my gtr makes 430kw at the wheels, and some of the previous tunes where very average,so its vital that the tuner knows what he's doing,the last tune i had was at advan and its quite awesome to drive with no issues at all,starts first time everytime
Does the link run utilize the O2 sensor?
PFC is a damn good no frills ECU.
6 inj drivers - Sequential inj.
6 coil drivers
Boost control
Injector Warning
Air-flow warning
Knock Warning
O2 Feedback (Closed loop)
VCT Control
fuel cut (rpm, overboost etc)
Perfect cold and warm start
Excellent idle control that rocks ign. timing and utilizes the AAC valve to hold flat idle.
Water Temp Compensation
Accelerator Pump
Airflow (load) and RPM scale is able to be modified
Ign. vs water temp correction
Ign vs air temp correction
Cold start ign. retard correction table to aid in engine warm up and drivability, emissions blah blah
Ign vs boost correction
Ign vs battery volts correction
Ign Dwell vs RPM correction
Anti-Lag
PFC versions are available that have launch control, ign cut instead of fuel and MAP.
What are the tech. specs on the Link? O2 control, inj. and ign. drivers, total load and rpm points available etc?
full ecu or standalone is a complete engine management system
piggy back is exactly that, it piggy backs onto the standard computer.
so parts of the car run through the piggy back and get changed and the rest runs to the normal. you can also get a remap which is the stock computer but with some values changed.
normally with a piggy back you have some limits in the system as you rely on the stock ecu still and you cant change the majority of stuff that a full replacement ecu has support to do
a piggy back is usually a air / fuel computer or ignition computer
a full ecu is a standalone engine management
piggy back usualy around $400 ish
stand alone $1000 +
