help needed, white smoke blowing out of exhaust
Guest tkch55
car: r33gtst series 2, around 80000km
mods: stock except for turbo back exhaust, turbo boosted to 10psi, k&n panel filter, oil catch can vented to atmo
when i was driving the car last night, my friend driving behind me told me that he didn't see any smoke coming out of the exhaust, except the exhaust fumes smelled a bit
however when parking my car into the garage, i realised that there's plenty of white smoke blowing out of the exhaust, the white smoke pretty much filled the whole garage, and it smells really bad, which i suspect it was burning engine oil
tried driving the car this morning, plenty of smoke came out of the car when idling, no smoke when driving, but smokes again when pulled up at the lights, which is quite embarrassing.
car still drives like normal, boost still comes on as usual and idle is perfect. drivability of car hasn't changed at all
although i've just changed engine oil from motul 8100 to 4100 turbolight on thursday, i'm guessing that it has nothing to do with it
checked dipstick, no sign of oil loss, oil is still really clean
oil catch can indicator is still showing empty since installation around 3 mths ago, tho the clear hoses that came with the oil catch can are a bit brown, but i believe this should be normal
from what i know, blown headgasket will make the engine oil milky as water will leak in, if it's piston rings then oil catch can will be filled really quickly, is this right? pls correct me if i'm wrong on this one
what are the other indications of blown head gasket and piston rings?
based on that, i'm guessing that i can exclude the possibility of blown headgasket or piston rings, but my question is, if it's a blown headgasket, or piston rings, would the car still drive and boost like normal? how about leaking turbo seals?
the turbo has a pretty audiable turbo whine since car was bought
so that led me to believe that it may be a leaking turbo seal? would that be right?
cheers
If you are running a catch can then your inlet tract should be clean. Pull off the pipes and check. If they are full of oil then the only place it could come from is the turbo.
But to complicate matters further, I had a blown headgasket on an old daily driver and no water was getting into the sump. Has your water temp increased? And is it like thick white smoke that lingers around or more closer to being steam?
Guest tkch55
thanks for the reply
the water temp is actually quite normal, the smoke is definitely the thick type that lingers around for a bit, and the quantity is so much that it can turn the garage into a smoke heaven in less than 20 seconds
in morning cold start its only a bit, but let it idle further for 20 seconds and the exhaust will start to smoke like crazy
Guest tkch55
started the car up again last night, it was fine without any smoke at all, took it for a drive for an hour or so, still no white smoke at all, exhaust smells normal
drove it to work this morning, and it's fine still
car still idles, boosts as normal
also checked the brake fluid last night, it's fine
now this puzzled me..
maybe it's just bad batch of petrol or something made its way into the fuel tank? the stopper at the fuel tank filler hole isn't sealed btw, so rain may make it's way in? (dodgy compliance work), or engine oil change from motul 8100 to 4100 turbolight caused this (which i doubt)?
oh well, at least she's fine for now
Id get the possibility of water getting into your fuel looked at... water cannot be compressed, so get a decent enough amount in there and welcome to the wonderful world of compression lock (worst case scenario, totally bent bottom end).
Has nothing to do with your original post, but sounds pretty dodgy :rofl:
i had the same problem ..when i changed oil weight....fixed it self when i put back the original weight oil i had in the beginning. also removed the catch can for now ..and its stopped.
Hope you didn't block any breathing line while installing catch can, i had same problem with my old car. Smoke came out so bad that i thought my turbo has gone but turned out to be the engine couldn't breath properly so it force oil through.
Another word is a BLOWN by. Hope this help.
Guest tkch55
ok the car started doing it again today, only for around 30 secs on idle then it's fine again
this time the white smoke didn't smell as much
checked the vacume line on the brake booster, it's clean so brake booster's not leaking
oil on dipstick is still nice and gold
water in the overflow is still at the max mark, checked the radiator and there's no sign of any water loss
car still boosts fine
what i realised was, this only happens occasionally after more than 30min drives, sometimes it doesn't do it even after an hour drive tho
if water did make its way into the fuel tank, due to water being denser than fuel, it should be at the bottom
hence the fuel pump should only pick up water, and no fuel at all isn't it? if so then i should be able to feel it quite easily when driving i thought?
didn't think that there's a block anywhere in the catch tank system, but if there was, such as too much steel wool, wouldn't the dipstick blow out? and shouldn't blow-by be blackish?
i had exactly the same oil catch tank setup on my old r32 and it was fine, so didn't think it'll cause anything after transplanting it to the r33
tho i didn't have it on the r32 for that long to find out anyway
took the car to a mechanic's place and problem's not occuring, so he couldn't figure out what went wrong either
cars always behave pretty well when they're taken to mechanics to diagnose certain problems...
but i might try taking out the oil catch tank and see how it goes for the next few days or so
anyway, thanx for the advise guys
Guest tkch55
i was thinking that it might be valve stem seals but actually..
i realised that when revving the car in neutral when parked, exhaust spits out water
so in other words inside my exhaust and especially cat, there's plenty of water
checked the hoses for the oil catch can, no sign of excessive amount of water vapour, while engin is running fine
my mechanic told me that the smell that came with the exhaust fumes the first time would have been from damaged cat due to the excessive amount of water trapped in it
cat's stuffed, good excuse to get myself a high flow cat
but now that the exhaust is cleaned and dried, car's fine again
maybe someone hosed in my exhaust? i don't know
If you sucked pure water into your engine, youd probably have a nice hole in the side of it (as said above, water doesnt compress... get enough of it into your engine and it will bend the bottom end to all hell and back).
Pull the radiator cap off and see if the fluid looks milky/oily.
Guest tkch55
water in radiator's checked
i'm sure no water's made its way into the engine, engine oil's nice and clear and so is the water in the radiator..
the radiator cap was pulled off number of times to check the level of water, the bleeding point near the intake plenum was checked also, colour looks fine and water didnt decrease at all
my mechanic's gone through the engine and found no leaks or any blown gasket
i guess i'll just leave it for now, it's not blowing steam anymore
thanks for your replies guys, appreciate it
cheers
hey there
i had the same problem after fitting upgradded injectors..
heaps and heaps of white smoke came out of the exhaust.
but i let the car idle for about 2 hours and it just went away
never to return and its been over 2 months now.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
