  • Replies 68
1986 camira, was the best v8 killer, if the v8 wasnt turned on that is. ha
it was literally a peice of shit, it seazed with 140000 on the clock, ***n peice of shit, my second car was a vltc, and i was still on my p's, although insurance was a whore to say the least. Best thing to think of buying a first car in my opinion is not power, not expereinced enough to handle the power, well thats my opinion. And it all depends on your taste, if u like skylines, why not buy an asperated line, then upgrade when the time comes.
1989 HSV SV89 Auto. Was a great car to learn on(mum gave this when she baught her 95 GSR Lancer - Wich was a awsome little car). Just before I got my P's baught a 1985 VK Calais Manual with a fairly well modded black 202 in it (managed a 14 flat out of it). Kept that for about 6months then got the R33 skyline. Had it for almost 3 years now. Would not go back. I'm glad that I had a powerfull car for my first. Cause it scared the shit out of me a few times. Enough to teach me to keep it off the streets.
'97 4 dr Rav4 auto.... go the rav! had it while on L's/ red P's
'04 subaru impreza RS 2.5L, still got it
'90 R32 GTR pick up next week, should be fun...
for a first car if you want something sporty but without insurance headache and new P plater power restrictions go a honda prelude, integra, civic, all great cars,
or if u wanna go AWD the subaru impreza RS 2.5L is a fantastic car! goes very hard, about the same 0-100 as a v6 holden/ford. very good suspension and AWD it doesnt get much better than that for a first car....
85 VK 3.3L carby (looked tough but lacked anything real). then went up and got another 85 VK but with a worked V8 5L. I can always count on my commodores to break down on me! good learning experience though.
im still on my L's and i bought a 94 R33 GTS25 in may just gone, i like it for a first car but already the power bug has bit me and i cant wait to upgrade to a GTS-t, im eligable for my P's next month and im planning to upgrade to a GTS-t in the very very near future.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
