First car? and what was yours?
1980 Daihatsu Charade- White, with a blue bonnet and black rust kill paint.. No looker but cheap to run, fun handling (VERY light), and surprisingly peppy for a 3 cylinder 993cc engine. Had it for 4 months before my parents wanted to help me get something 'safer and more reliable'.
Next was a 1993 charade, lacked the character of the 1980 tho. Then 2 XF falcons (what WAS i thinking).
Now i've got a 91 MX83 cressida, thats demanding more and more in repairs/upgrades so a R33 SII is in the works...
(so if anyone wants a cheap MX83 pm me -its a good base for a 1jz conversion, i simply dont have the time or space to do it)
  • Replies 68
1998 R33 gts-t.. prior to that.. never had one :P..
but been driving for long time - used parents cars/brothers car on and off. live near the rail line though
didnt know there was a 98 model r33 gts-t??
i got a lh torana, which i kept for roughly three and a half years (slowly building it up) and had it until just the start of this year when i imported the r32 gts4. i gave it a hiding, but the thing never 'broke down' so to speak.. it just ran like crap after all the mods and was a real pain in the but to drive all the time. ive since sold it.. *wipes a tear*
s.
Datsun 180b.
Doesn't work any more though, ripped the engine apart with an angle grinder and arc welder. So yeah, probably going to wait and buy an 808 or RX3 shell (depending on how long I wish to save...)
Mine was an EA falcon with multi colour doors, and on gas. Still have it as a run about, 300 000kms on the clock and still going strong! :rofl:
WAS going strong. It died :) looks like it will be needing a new engine.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
