  • 3 weeks later...
  • 4 weeks later...
We have a one off deal here! Only 1 kit available.
The IHI Power Enterprise PE150TR kit is good for 480PS.
A direct bolt on to the RB26 including gaskets, studs, Dumpys.
A very strong and responsive bolt on.
This kit retailing normally at just on $5k. We can have this
kit delivered within 7 days to your door for $3400.
Output 480ps/6500rpm
Torque 70kgm/5800rpm
Boost 1.4kg/cm2
with 70mm diameter outlet pipe
Actuators included
HALTECH E6X ECU. S15 base map included.
For Sydney residents, they can see this computer operational in my S15. This unit can be installed in WRX's and Skylines also.
The ECU comes complete with electronic boost controller, MAP sensor, Launch trim module and software.
Genuine enquiries can be made via PM or email at [email protected]
$900 complete.
$40 shipping interstate.
Available now!!!
Edited by JDMimports
  • 3 weeks later...
  • 3 weeks later...
BNR34 GT-R N1 turbines NEW~! $4500 landed
HKS GT2540 turbines with HKS actuators.NEW $5500 landed.
R34 GT-R turbines. almost new. $4000 landed
dump pipes
actuators
just a few examples of what's available in Japan at the moment. these items close Early October.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
