Hey as some might know i am in the market for another car, i have been thinking and thinking. I have decided i want a car to use for drift and hopefully enter the drift nationals next year, thats not the point. What i want to know is and yes i searched! what are the prices involved in importing a car for track use?
This thread was alot of help but didnt give me exactly what i was after:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=75261
Borrowed this from 25det hope he doesnt mind...
out of all these prices which ones are necessary?
prices all approx
Freight - $1200
Duty tax - 10%
Customs - $500
GST - 10%
Compliance - $3500
Stamp Duty - 2%
Tyres - Depends
also will i need a cams licence if i want to use it for drift?
any help is gladly appreciated. I do not want a car to drive on the streets i already own a 180sx and its enough for the time being. I want something which i can modify, wont have to worry if i hit a wall or the paint gets scratched if you know what i mean.
Do jspec and prestige allow you to purchase cars through them and use it for track use only?
I had in mind either a R34 4 door and make it into something similar to the Blitz R34 in D1 or maybe a 2 door r32.
If anyone knows of someone selling either cars in manual turbo not complied and ready for track use or stock doesnt bother me please pm me. Do not pm me with cars that are registered.
Also i wouldnt mind a R34 4 door rolling shell and building it up. Either way please pm me with offers, pics, prices, info.
https://www.sau.com.au/forums/topic/79976-importing-a-car-for-drifttrack-use/
This following thread is going to be of some use to you (http://www.skylinesaustralia.com/forums/sh...ead.php?t=76844).
- From those costs above you wouldn't need compliance or tyres, everything else would still apply (I'm pretty sure).
- The application for import approval would require you to have this prior CAMS experience., ie you can't just say you want to import a race car - see DOTARS link for more info (http://www.dotars.gov.au/transreg/vsb/vsb_10.aspx#5.10)
- Jspec and prestige are more than happy for you to purchase track cars through them..
You need a C3 or R3 licence to bring in any race/rally car, if C3 it is for track use only with import approval not allowing rego and R3 for track, rally and targa type events with approval for street rego but limited use.
Do they ping you for stamp duty ?
Cheers,
Lucien.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
